Backup and failover recommandations
todd.johnsen
I have two 5508 WLC's setup to run about 200 AP's as the moment.  This is a hospital with patient care now running over wireless.  I am looking for the best scenario to minimize down time.  Currently both controllers are in the same mobility group and I will be setting the primary / secondary controller in the High Availability tab for each AP.  Most setting are all default still.
My question:
Would it better to setup the primary/secondary from the global configuration?
Can I leave them in the same mobility group if I use the global configuration?
My only problem so far is having AP's on different controllers caused some response delay as clients move from one controller to the other.  I need to find the best possible response time with the lowest possible fail-over time.  Any recommondeations or links to a good article on this subject?
Todd
Stephen Rodriguez
What you would want to do is set the Primay/Secondary on a Per AP basis, the global configuration are technically 4th and 5th in the WLC failover process.
You could do this via the CLI, or NCS/WCS if you have it.
Yes keeping them in the same mobility group would be preferred.
As for the roaming, are the WLC using the same layer 2 vlan/subnets, or are they using different ones?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Both WLC's are in the same subnet.  I had one AP out of six in a patient area switch over to the secondary and there was a strange delay when clients moved in and out of that AP area.  I figured it was relating to a different management IP or something.  Of course that was before I read up that both WLC should have the same Virtual IP...
I have read some instructions for changing the timeout’s and polling.  Does anyone recommend this or are the defaults acceptable? I want minimal downtime but I also need stability. Anyone have horror stories they want to share or some best practice advice?
If you need AP SSO then use the new HA from 7.3 code.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
