05-18-2019 11:48 PM - edited 07-05-2021 10:26 AM
Hi all,
First of all, I would like to thank u all in advanced.
I have a couple of Meraki Wireless Access Points installed at my office. And I want to add some specific rules as below. First I want to know whether it is possible for me to add rules as I desire. And then I would like to know how to do so.
E.g. If the user Bob has consumed 500mb on Facebook his bandwidth should be limited to 5mbps for the month of May. After the month of May, he should get a fresh unthrottled bandwidth to use Facebook up to the maximum data cap of 500mb. And other users who have not exceeded the data limit should not be affected.
E.g. Even Bob should be able to get the full bandwidth to browse Facebook from 1800 hours to 0830 hours.
Thanks.
05-19-2019 01:26 AM
We have some deployments for QoS, not for time based,
but below guide should able to help to tweak as per your requirement.
05-19-2019 01:34 AM
05-19-2019 02:07 AM
I have not tried as per the document it can be done(until some one tested and coments)
in the Traffic shasin i can see per client bandwidth limit with policies (is this what you looking ?)
05-19-2019 04:59 AM
05-19-2019 05:49 AM - edited 05-19-2019 08:07 AM
Honestly i have not tested that feature. should be possible in normal enterprise network AP / WLC other supporting environment.
not sure meraki side, so wait for other collegues to comment, who had done this testing.
05-19-2019 06:08 AM - edited 05-19-2019 06:08 AM
Meraki only support bandwidth shaping and not features such as shaping users after they consumed X amount of MB.
I've doubled checked as on the Meraki Dashboard under the MX64 and the MR33, both their bandwidth shaping features don't support your request.
Find reference below of what you can configure.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/Traffic_and_Bandwidth_Shaping
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
05-19-2019 01:16 PM
Meraki does not support this type of shaping once a user reaches a limit of a particular type of traffic.
For this you would need to look at another solution, more than likely a proxy server (on prem or cloud based).
