08-13-2015 08:46 AM - edited 07-05-2021 03:45 AM
Is their a way to block a device from accessing one SSID and allowing access to another SSID? This is a controller base wireless network. I would like to allow access of a certain device to the corporate network and deny access to the public network. I want to keep both SSID's on all access points.
Thanks in advance!
08-13-2015 08:07 PM
https://supportforums.cisco.com/discussion/11451031/block-single-client-mac-address-one-ssid-wlc
08-14-2015 06:24 AM
Thanks Ric! I will look into this.
08-18-2015 10:42 AM
Yes it is Possible using "Mac Filtering on controller".
For step by step configuration check the link.
https://www.cisco.com/assets/sol/sb/isa500_emulator/help/guide/ae1244606.html#Rae75180
Do mark as correct if it help ;)
