ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Block P2P traffic on Cisco 5508 Controller
Is it possible to block outside P2P traffic on a guest wireless network using an ACL on the controller?  I know we can do it our firewall but the question came up so I thought I would post and see what everyone thinks.  TIA
6 REPLIES 6
Highlighted
Beginner
What you can do is, to block P2P traffic inside a SSID.
Can be configured on a per-SSID basis.
regards,
    Dirk
regards, Dirk (Please rate if helpful)
Highlighted
Beginner
I believe on the WLC under the WLAN you are referring to, click on the Advance tab and there is a P2P blocking action. I believe that will help you out with what you are wanting to do.
Highlighted
Beginner
Thanks to all who replied.  I already restrict P2P for the SSID.  I was curious about blocking internet/outside P2P.
Again Thanks!
Highlighted
Yes, ACLs can be applied to the WLC. I might suggest moving the ACL to the closest point, the FW if you are concern about internet traffic.
ACLs on Wireless LAN Controllers: Rules, Limitations, and Examples
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00807ce372.shtml
Highlighted
Beginner
Thanks for all the info and the link.  It is very helpful.
Highlighted
No problem. Stop back if you have any other issues or questions.
Content for Community-Ad
