01-26-2018 07:50 AM - edited 07-05-2021 08:10 AM
I am trying to reach the WLC using GUI, SSH and telnet in a Flex Connect environment but i can't, tho i can ping it.
Does anybody have had any similar issue ?
BR!
01-26-2018 07:54 AM
01-26-2018 08:00 AM
Hi Francesco,
Yes, i am trying using WIFI, I have selected the checkbox on the wlc to do that.
When I am connected to a local AP I can access the wlc without problem, but when i move to a branch office with Flex AP I cant. I wanna know if that is a normal behavior or is there any misconfiguration.
BR!
01-26-2018 08:03 AM
01-26-2018 08:07 AM
Yup, mgmt-via-wireless capability activated.
There are no Firewalls between offices, they communicate with the sw cores
01-26-2018 08:22 AM
01-26-2018 08:42 AM
I have never tried that, from the wlc i can not ping the gw in the branch office.
Could be a routing issue ?
01-26-2018 11:05 AM
Cab you check any acl and routing ?
Can you share a traceroute from branch and from your central site?
01-26-2018 11:09 AM
01-26-2018 11:26 AM
this is the output.
192.168.2.11 is the wlc
192.168.2.2 is the sw core in central office
192.168.102.6 is the sw core in branch
from central to gw, wlc and branch
SWACCESS13-MCS#ping 192.168.2.11
Sending 5, 100-byte ICMP Echos to 192.168.2.11, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/14 ms
SWACCESS13-MCS#ping 192.168.2.2
Sending 5, 100-byte ICMP Echos to 192.168.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/6/14 ms
SWACCESS13-MCS#traceroute 192.168.2.2
Tracing the route to swcore (192.168.2.2)
VRF info: (vrf in name/id, vrf out name/id)
1 swcore (192.168.2.2) 4 msec * 3 msec
SWACCESS13-MCS#traceroute 192.168.2.11
Tracing the route to 192.168.2.11
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
Tracing the route to 192.168.102.6
1 swcore (192.168.2.2) 3 msec 4 msec 3 msec
2 172-10-25-4.lightspeed.rlghnc.sbcglobal.net (172.10.25.4) 3 msec 4 msec 4 msec
3 192.168.102.6 3 msec * 7 msec
from branch to cetral core and wlc
SWCORE-MCS-INFRA#traceroute 192.168.2.11
1 192.168.102.2 0 msec 0 msec 8 msec
2 172.10.25.1 9 msec 59 msec 17 msec
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
SWCORE-MCS-INFRA#traceroute 192.168.2.2
Tracing the route to 192.168.2.2
1 192.168.102.2 0 msec 0 msec 0 msec
2 172.10.25.1 8 msec 0 msec *
When i change Flex AP to local mode, then I can reach the WLC.
BR
01-26-2018 12:57 PM
11-14-2019 09:38 AM
I am probably responding late to this but I an tell you I have the same issue
Local Mode no issue, Flexconnect cannot get to WLC Mgmt
I am not behind a firewall as my WLCs are internal and so is my MGMT interface, My firewalls along with most are at the parimeter so the request to reach the MGMT interface doesn't ever reach the Firewall
in short, this should NOT be a firewall issue clearly stated by the fact that simply moving the AP from Flexconnect mode to Local mode allows access and the MGMT interface or the implementation doesn't change, in both cases we still need to access the Same IP Address. What happens in Local vs Flexconnect mode is where my mind is trying to solve along with many others scratching heads wondering what's the traffic doing in both modes during the request to reach the MGMT
11-15-2019 05:17 PM
When you're connect to a local or a flexconnect AP, if you have enabled management access, you should be able to access your WLC.
The difference is your traffic is being switched locally on the switch at the branch. Are you trying to access the management interface or a dynamic interface? Can you run a wireshark and try again please? share the wireshark capture if you can please.
01-26-2018 10:12 AM
01-26-2018 11:06 AM
