08-09-2013 11:18 AM - edited 07-04-2021 12:37 AM
I was having some problem witch prime infrastructure 1.3, so i decided to do a ncs db reinitdb (after backin up ncs). So evererthing went well and after the operation, i am unable to access the web interface. I change the root password but even after this, i'm still unable to log in! I also rebooted several time, but still no success. I need some help!
08-09-2013 11:22 AM
What does the show application status NCS show.
08-09-2013 11:29 AM
Here is what i get:
Health Monitor Server is running.
Reporting Server is running
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is running.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
status
08-09-2013 11:31 AM
Well the web service is running.
You might just want to open a TAC case for this and hopefully get it fixed without have inf to rebuild another one.
08-09-2013 01:37 PM
If you are good with Linux, you can go to the root shell and you will see that the IP address you set will not show up. Instead you will still see the default IP. The disparity in IP is what is affecting the GUI from working. Best you open a TAC ticket as suggested.
Sent from Cisco Technical Support Android App
08-16-2013 02:39 AM
Do the following in the root shell (Note you have to be handy with Linux commands)
- go into /opt/CSCOlumos/logs
- Open nms_launchout.log and you may notice that the application is trying to open a socket on an IP that was different from the actual IP of the device.
- go into /opt/CSCOlumos/conf and edit messaging.conf with the correct IP address
- Restart services
08-21-2013 11:48 AM
Logging into Cisco Prime Infrastructure for the First Time
Once the Cisco Prime Infrastructure server has been installed and configured, it is now ready to be accessed from the web. The server URL would be https://server_hostname or https://ip.ad.dr.ess. In Cisco Prime Infrastructure 1.3, login using the following credential for the very first time:
Username: root
Password:
After the server has been configured, it is advisable to log in with a non-root user to keep the root user for system level configurations as and when needed. More updated information can be found at Prime Infrastructure 1.3 Quick Start Guide at Logging into the Prime Infrastructure User Interface
08-21-2013 06:16 PM
None of the solutions above worked!
The TAC looked at it and the problem seem to be a little bit complicated.
08-22-2013 02:48 AM
I described a solution to a similar problem as yours and it worked for some people. The link is below:
https://supportforums.cisco.com/thread/2201565?tstart=0
I have also described the steps below:
Please do the following:
1. Go to root shell by typing root and enter the password
2. Go to the home directory by typing /opt then hit enter
3. Enter cd CSCOlumos
4. Enter cd conf
5. enter ls to list the files
6. You will see messaging.properties. To view this file, enter cat messaging.properties
7. Check the IP address that shows to make it isn't different from the IP address that you had configured
8. If different, edit the file by typing vi messaging.properties and hit enter
9. press i to allow you to insert. Move the cursor to the line that you want to change and type in the correct IP address
10. Press ESC, the escape key to leave the VI editor.
11. Press the colon (:) key then type wq. That is ":wq". This will save the file and exit
12. type cat messaging.properties to view the file and verify the changes were effected.
If this solves your problem, mark question as answered so that others can learn.
Cheers
