Community Helping Community
741
Can't reset Access point
I have an access point running 15.5.2(JA). I can't do a hard reset, well the guy that is with it can't,  the access port is a long way away and it won't let me delete the config. I've never set one of these up before and pushed for time. We don't have a WLC wanted to run in autonomous mode.
How can I get that access point in a way that allows me to config from a webpage? The ios commands it gives me are very different from the standard switch i.e I cant do "erase running-config"
I can get to the CLI but ...
Everyone's tags (1)
8 REPLIES 8
Hall of Fame Master
Re: Can't reset Access point
First of, it the ap lightweight or autonomous?
-Scott
APfc99.47c8.518a#show ver
Cisco IOS Software, C3600 Software (AP3G2-RCVK9W8-M), Version 15.2(2)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 23-Aug-12 02:43 by prod_rel_team
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(23c)JY, RELEASE SOFTWARE (fc1)
APfc99.47c8.518a uptime is 19 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
All the documentation says I should be able to do a conf t but it doesnt give me a config option? If I try a ? config is not an option but its not in rom mon mode or anything like that?
We want to run it in auto mode.
Thanks for your help!
Hall of Fame Master
k9w8 is a light weight image. K9w8 is an autonomous image. You will need to
Download the IOS autonomous image and soma conversion which requires you to have the AP in your hand.
Here is a handy document that explains the process
https://supportforums.cisco.com/docs/DOC-14960#LWAPP_to_IOS
-Scott
Thanks. If I get a WLC does that allow me to get this up if I don't upgrade the image?
Hall of Fame Master
Yes... It would be better to manage also I'm my opinion.
Here is a doc that explains the join process which allows the AP for find the WLC
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
-Scott
Hall of Fame Master
Here is another doc. Hope this helps explain things
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
-Scott
Highlighted
Thanks very much for your help. I've been banging my head against the wall with this for the last few hours! Thanks again!
Hall of Fame Master
No problem
-Scott
Content for Community-Ad
August's Community Spotlight Awards
