Can we use only certificate based authentication for user authentication using Cisco WLC with external Radius server
I have a cisco WLC 3504 and Ubuntu Radius Server  which works as the external Radius server.
I want the wireless clients to be authenticated using certificates and what will be SSID security settings for this?? Is there any documentation link for this??
Haydn Andrews
Effectively the you need to do following:
Add the RADIUS server to the WLC
Configure the WLAN for WPA2 Enterprise 802.1x authentication AS per the WLC parts of this document:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213543-configure-eap-tls-flow-with-ise.html
Where it goes through ISE configurations you need to configure your RADIUS server to EAP-TLS
Here is how FreeRADIUS does it:
https://documentation.meraki.com/MR/Encryption_and_Authentication/Freeradius%3A_Configure_freeradius_to_work_with_EAP-TLS_authentication
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hi Afroza,
Please refer this Configure-802-1x-PEAP-with-FreeRadius
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Haydn Andrews
Hello  Haydn,
The solution has worked thanks for your help.
I have another query, the radius server expert says that they need 60s to verify the certificate and asked me  is there any option in WLC where I have to put timer for this 60s certificate validation.
Glad i could help, make sure you help others out by marking solutions as accepted solutions.
Around timeouts, 60 seconds is a very long time, from a client prospective it it takes 60 seconds to authenticate i'm giving up or logging a ticket. Normally if the RADIUS server is in the same network segment as the WLC then for TLS I have never seen requirement to go past 5 seconds.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_01010.html
there are also some best practices for EAP style authentications here:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/118703-technote-wlc-00.html
