153
Can we use only certificate based authentication for user authentication using Cisco WLC with external Radius server
I have a cisco WLC 3504 and Ubuntu Radius Server  which works as the external Radius server.
I want the wireless clients to be authenticated using certificates and what will be SSID security settings for this?? Is there any documentation link for this??
1 ACCEPTED SOLUTION
Rising star
Re: Can we use only certificate based authentication for user authentication using Cisco WLC with external Radius server
Effectively the you need to do following:
Add the RADIUS server to the WLC
Configure the WLAN for WPA2 Enterprise 802.1x authentication AS per the WLC parts of this document:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213543-configure-eap-tls-flow-with-ise.html
Where it goes through ISE configurations you need to configure your RADIUS server to EAP-TLS
Here is how FreeRADIUS does it:
https://documentation.meraki.com/MR/Encryption_and_Authentication/Freeradius%3A_Configure_freeradius_to_work_with_EAP-TLS_authentication
*****Help out other by using the rating system and marking answered questions as "Answered"*****
4 REPLIES 4
Hi Afroza,
Please refer this Configure-802-1x-PEAP-with-FreeRadius
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Rising star
Highlighted
Hello  Haydn,
The solution has worked thanks for your help.
I have another query, the radius server expert says that they need 60s to verify the certificate and asked me  is there any option in WLC where I have to put timer for this 60s certificate validation.
Rising star
Glad i could help, make sure you help others out by marking solutions as accepted solutions.
Around timeouts, 60 seconds is a very long time, from a client prospective it it takes 60 seconds to authenticate i'm giving up or logging a ticket. Normally if the RADIUS server is in the same network segment as the WLC then for TLS I have never seen requirement to go past 5 seconds.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_01010.html
there are also some best practices for EAP style authentications here:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/118703-technote-wlc-00.html
