Cannot change IP on WLSE
mikeb
Help - I have assigned an IP to eth1 which I would now like to change. Unfortunately nothing happens when I issue the command. It does not even respond to the 'interface eth1 down' command. I am running WLSE 2.13. I've reloaded several times with no success.
Thanks in advance.
rmushtaq
Level 8
Level 8
The default interface for WLSE is eth0, not eth1. Unless you plan to use both interfaces at the same time. Is this the case?. For changing the eth0 ip address, you can simply run the setup command from the CLI as admin user which will let you change it Once configuration is set, it will reboot the appliance.
