Highlighted
Beginner
CCKM Dissassociation message
Folks,
            I have 2 access points which are far apart from each other. I have 802.1x+cckm enabled for my cisco Wireless ip phone. When I move from one AP closer to the other. The phone call disconnects. I was running a debug on the controller while roaming and this is the error message I saw:
%APF-3-CREATE_CCKM_REASS_RESPONSE_IE_FAILED: Could not build the CCKM
Reassociation response IE.[chars]. Mobile: [hex]:[hex]:[hex]:[hex]:[hex]:[hex]
Any way I can fix this problem.
Parwal
2 REPLIES 2
Highlighted
Re: CCKM Dissassociation message
What's the controller code.
What's does the show msglog look like. You might be sending a cckm reassociation request that is invalid.
Finally there should be sufficient coverage to enable seamless roaming
Run
Debug cckm detailed enable along with
Debug client Mac addr of client
Highlighted
Beginner
Navin, did you get a fix for this issue? Please post the fix if you did.
Tracy
Content for Community-Ad
