11-05-2013 08:26 AM - edited 07-04-2021 01:13 AM
Good Morning,
I have a question about CCKM, do I need to deploy CCKM compliant hardware, or will my existing hardware work with a CCKM enabled set of AP's? My customer uses WPA2 with CCKM on their network. My wireless hardware knows nothing of CCKM it can accomodate WPA2 protocols, and to that end works well.
thanks
Sandie
Solved! Go to Solution.
11-05-2013 08:58 AM
Yes the hardware you deploy needs to be CCX compatible to be able to utilize CCKM.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
11-05-2013 10:23 AM
If you choose cckm your client needs to support it or it won't connect. On the WLC you can select 802.1X and CCKM .. This way you can cover both ..
I will mention I have seen issues with this setting on some clients ..
11-05-2013 08:58 AM
HTH,
Steve
11-05-2013 10:03 AM
I do have a followup question, will my device connect if it doesn't have CCKM and I do not want to utilize it?
thanks
Sandie
11-05-2013 10:23 AM
11-07-2013 11:10 AM
Thanks for supporting the rating system!
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
