3934
Beginner
Changing AP 1230 and 1231 from lightweight to autonomous
Hi. I cannot TFTP this tar file to both 1230 and 1231 APs. Both are lightweight APs that I've wiped to the rommon mode (ap>) and I issue the command:
tar -xtract c1200/k9w7-mx.123-8.JA 10.0.0.2
And I get a error saying: "permission denied"
Notes:
The AP has defaulted to the 10.0.0.1 IP.
My laptop is set to 10.0.0.2 255.255.255.0 IP
My TFTP-Server is on and the root folder with the .tar file is in there.
ether_init, flash_init, tftp_init (these commands have been executed)
My firewall is disabled.
SO, with all that being said, WHY DOESN'T THIS WORK!???
18 REPLIES 18
Highlighted
Hall of Fame Community Legend
The fastest and easiest way of converting an AP from lightweight to autonomous (without an AP) is by this method below:
Using a TFTP Server to Return to a Previous Release
Beginner
I tried that. No go. As soon as I've done all those steps. I reboot the AP and it defaults back to being a LWAPP.
Can you please post the output to the command "dir flash:" please?
Beginner
ap: dir flash:
Directory of flash:/
153  drwx  128                      c1200-rcvk9w8-mx
3    -rwx  15384                    private-multiple-fs
4    -rwx  826                      env_vars
6    drwx  320                      c1200-k9w8-mx.124-23c.JA3
12   -rwx  99192                    event.log
2338304 bytes available (5403136 bytes used)
you should be able to sit on the console and watch the AP pull the image from your TFTP server.  Try the mode button reload again while you're on the console.
also make sure that 'show known file types' is enabled
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Beginner
Tried it at least 2 dozen times over the past 3 days. 'Show know file types' is enabled.
I'm gunna chuck these old Cisco APs out the office window...I swear....lol.
The Cisco Upgrade tool only changes a autonomous to LWAPP correct? Not vice versa? I've tried using the upgrade tool on a Wins7 and WindowsXP machine and it keeps giving me an error saying another TFTP server is in use...when it isn't. It's lying!
Beginner
This is the OUTPUT WHEN I BOOT: (My TFTP Server is ON, my firewall is OFF, the mode button is pressed for 35 secs.)
Xmodem file system is available.
flashfs[0]: 10 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 5403136
flashfs[0]: Bytes available: 2338304
flashfs[0]: flashfs fsck took 15 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:0f:24:5b:5f:11
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbs, full-duplex
Ethernet port 0 initialized: link is up
button is pressed, wait for button to be released...
button pressed for 27 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/c1200-k9w7-tar.default
examining image...tftp://255.255.255.255/c1200-k9w7-tar.default: no such file or directory
ERROR: Failed to open archive file tftp://255.255.255.255/c1200-k9w7-tar.default
download takes about 0 seconds
Loading "flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx"...########################################################                                                   #############################################################################################################                                                   ####
File "flash:/c1200-rcvk9w8-mx/c1200-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1200 Software (C1200-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:41 by alnguyen
Image text-base: 0x00003000, data-base: 0x00359FC0
Initializing flashfs...
flashfs[1]: 10 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 5403136
flashfs[1]: Bytes available: 2338304
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-AP1231G-A-K9     (PowerPC405GP) processor (revision A0) with 15038K/1336K bytes of memory.
Processor board ID FHK0806J27X
PowerPC405GP CPU at 196Mhz, revision number 0x00C4
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0F:24:5B:5F:11
Part Number                          : 73-8704-06
PCA Assembly Number                  : 800-23211-07
PCA Revision Number                  : A0
PCB Serial Number                    : FOC080512J4
Top Assembly Part Number             : 800-23304-07
Top Assembly Serial Number           : FHK0806J27X
Top Revision Number                  : B0
Product/Model Number                 : AIR-AP1231G-A-K9
Press RETURN to get started!
*Mar  1 00:00:05.109: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:06.034: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:07.034: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:00:15.032: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:24.122: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:24.155: SSC Load Current Size crypto_mykey 116, offset 9416, Saved Size soap_cert_crypto_mykey                                                    124
*Mar  1 00:00:24.155: SSC Load Current Size crypto_mykey 116, offset 10427, Saved Size soap_cert_crypto_mykey                                                    124
AP000f.245b.5f11>
Hall of Fame Master
Looks like the path you specified in the root tftp doesn't have this file.  You should be able to ping the AP also which will default to 10.0.0.1 255.255.255.0.  Can you ping the AP when the AP has booted up?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Beginner
The .tar file is in the TFTP Root folder. Also, I can't ping to the AP because if I let it boot like I did above, the
'tar -xtract c1200/k9w7-mx.123-8.JA 10.0.0.2'
command won't work.
If I unplug my Ethernet cable, allow the AP to boot, it will stay in ROMMON mode with the 'ap>' prompt. If I connect my cable then, it a few seconds before I can even try to ping the 10.0.0.1 address, it will boot up all the way to the
'AP000f.245b.5f11>' prompt.
See my dilemma?
so dumb question.  when attempting this ,what is the IP and mask on your nic?
HTH,
Steve
Beginner
PC: 10.0.0.2/24 (255.255.255.0)
Ummmm ... that's not right.  It should be /8.
Scott's right.  The file doesn't exist or your TFTP client is pointing to the wrong directory.
Hall of Fame Master
The mask shouldn't really matter if your using 10.0.0.2 on you PC.  I use /24:)
What I would do is use 3CDeamon and put that on another machine and use one as a tftp server and the other as a client and see if you can put or get a file.
Scott
-Scott
Beginner
The file does exist:
C:\TFTP-Root\c1200-k9w7-tar.default.tar
And the TFTP Client is pointing to this folder above.
Content for Community-Ad
August's Community Spotlight Awards
