Changing default tftp server at NCS
holgerseiler
Hi all,
at a customer side I had installed a NCS at a virtual machine. Last week we had to change the IP address to another Network. At this point my autonomous migrations to CAPWAP failed, because the APs want to upload the env_var to the default tftp server. The default tftp server at NCS have the old IP before the ip address change.
How could I change the IP address to the new one?
Kind regards
Holger
aaroncoffman
Holger,
I assume this has been resolved or you've found a work around by now. But did you try to SSH into the NCS? When I show run in my NCS I see the following for the defaultRepo. As far as I know this wasn't changed.
repository defaultRepo
  url disk:/defaultRepo
As you can see, there's not much to it. If you wish to alter a repository do the following.
  1. Enter global config mode (ssh)
  2. enter 'repository [name of repo]
  3. have fun.
Aaron
