03-10-2020 09:04 AM - edited 07-05-2021 11:50 AM
Hi I have some Access Points that have left holes in the coverage, this is mainly on the 2.4 ghz if i change manually change the power levels on these will it affect the power levels of other Access Points that have their power set Globally and cause other problems
03-10-2020 09:40 AM
03-10-2020 09:51 AM
Hi I am not where I can look at the TPC setting, it would be what is set out of the box.
There was a certification performed, the 5ghz was fine but some areas the 2.4 was out of -67 scope.
So the controller does not differentiate if power is manually set or global it will adjust the globally set access points as needed
03-11-2020 12:39 AM
03-10-2020 10:57 AM
how did you determine that there is a coverage hole at 2.4 GHz ?
