11-14-2019 03:47 PM - edited 07-05-2021 11:18 AM
I had 2 1852i APs running mobility express that was running 8.4.100 code for a couple of years with no issue. A few days ago one of the APs stopped checking in and I noticed it doesn't seem to be booting all the way. if i get into the console i see it hangs and has the following errors:
Username: [*01/01/1970 00:00:36.5887] AP1852I [*01/01/1970 00:00:36.6987] nss_driver - Turbo Support 1 [*01/01/1970 00:00:36.6987] Supported Frequencies - 110Mhz 550Mhz 733Mhz [*01/01/1970 00:00:36.7287] NSS firmware booted [*01/01/1970 00:00:36.7587] NSS firmware booted [*01/01/1970 00:00:36.8486] [*01/01/1970 00:00:36.8486] phy_value=0: org="0x1000" phy_reg="0x1800" [*01/01/1970 00:00:37.2285] Current value of FACTORY_RESET=0 [*01/01/1970 00:00:37.2485] Last reload time: Aug 18 21:01:12 2017 [*08/18/2017 21:01:12.0000] Setting system time Fri Aug 18 21:01:12 UTC 2017 [*08/18/2017 21:01:12.0599] device wired0 entered promiscuous mode [*08/18/2017 21:01:12.1299] device wired1 entered promiscuous mode [*08/18/2017 21:01:12.5298] stile module dp init successfully [*08/18/2017 21:01:12.5298] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Nov 1 2016 at 16:53:57 [*08/18/2017 21:01:13.1696] miibus get eec91400! [*08/18/2017 21:01:13.2096] [*08/18/2017 21:01:13.2196] boot 10671 build T-ea744460b77c6aa805022a071636bbe91bfbef81-gea744460-vipendya board corsica mac 70:D3:79:E8:5F:50 [*08/18/2017 21:01:13.2196] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070 [*08/18/2017 21:01:13.2196] Module: aptrace .text=0xbf00c000 data=0xbf014044 bss=0xbf014448 [*08/18/2017 21:01:13.2196] Module: led_module .text=0xbf01b000 data=0xbf01b3cc bss=0xbf01ba34 [*08/18/2017 21:01:13.2196] Module: qca_nss_gmac .text=0xbf01f000 data=0xbf025be0 bss=0xbf0260a4 [*08/18/2017 21:01:13.2196] Module: qca_nss_drv .text=0xbf02f000 data=0xbf04a050 bss=0xbf04ae00 [*08/18/2017 21:01:13.2196] Module: qca_nss_capwapmgr .text=0xbf06b000 data=0xbf06fa88 bss=0xbf06fbd8 [*08/18/2017 21:01:13.2196] Module: nssmgrctl .text=0xbf076000 data=0xbf077730 bss=0xbf077a54 [*08/18/2017 21:01:13.2196] Module: proclikefs .text=0xbf07d000 data= bss=0xbf07db40 [*08/18/2017 21:01:13.2196] Module: stile_lm_ft .text= data= bss= [*08/18/2017 21:01:13.2196] Module: stile_lm_dp .text= data= bss= [*08/18/2017 21:01:13.2196] Module: ipv6 .text=0xbf9c8000 data=0xbf9f8fc0 bss=0xbf9fa86c [*08/18/2017 21:01:13.2196] Module: bonding .text=0xbfa14000 data=0xbfa25644 bss=0xbfa25a70 [*08/18/2017 21:01:13.2196] Module: lowmemorykiller .text=0xbfa32000 data=0xbfa322c0 bss=0xbfa3244c [*08/18/2017 21:01:13.2196] Module: qca_nss_profile_drv .text=0xbfa36000 data=0xbfa37320 bss=0xbfa37494 [*08/18/2017 21:01:13.2196] Module: ssdk_reg .text=0xbfa3c000 data= bss=0xbfa3c838 [*08/18/2017 21:01:13.6695] Last reload reason : 0: unknown [*08/18/2017 21:01:13.8794] set led_patteren 12 [*08/18/2017 21:01:15.3090] __mm_init_module [*08/18/2017 21:01:15.3589] [*08/18/2017 21:01:15.3589] __ol_ath_attach() Allocated scn edf80480 [*08/18/2017 21:01:15.3689] ol_ath_attach interface_id 0 [*08/18/2017 21:01:15.3689] Chip id: 0x9, chip version: 0x1000000 [*08/18/2017 21:01:15.3689] [*08/18/2017 21:01:15.3689] Target Version is 1000000 [*08/18/2017 21:01:15.3689] [*08/18/2017 21:01:15.3689] Flash Download Address c0000 [*08/18/2017 21:01:15.3689] ol_transfer_bin_file: flash data file defined [*08/18/2017 21:01:15.3689] Cal location [0]: 00000000 [*08/18/2017 21:01:15.3689] [*08/18/2017 21:01:15.3689] Wifi0 NAND FLASH Select OFFSET 0x1000 [*08/18/2017 21:01:15.3889] qc98xx_verify_checksum: flash checksum passed: 0xebce [*08/18/2017 21:01:15.3889] ol_transfer_bin_file 3754: Download Flash data len 12064 [*08/18/2017 21:01:15.4089] [*08/18/2017 21:01:15.4089] Board data initialized [*08/18/2017 21:01:15.4589] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660 [*08/18/2017 21:01:15.4589] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1 [*08/18/2017 21:01:15.4589] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin [*08/18/2017 21:01:15.5389] [*08/18/2017 21:01:15.5389] [Flash] : Ignore Module param [*08/18/2017 21:01:15.5389] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0 [*08/18/2017 21:01:15.5689] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin [*08/18/2017 21:01:16.6685] HTC Rx: insufficient length, got:4 expected =8 [*08/18/2017 21:01:16.6785] Startup Mode-0 set [*08/18/2017 21:01:16.6785] HTC Service:0x0300 ep:1 TX flow control disabled [*08/18/2017 21:01:16.6785] HTC Service:0x0100 ep:2 TX flow control disabled [*08/18/2017 21:01:16.6785] Firmware_Build_Number:70 [*08/18/2017 21:01:16.6785] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffaa [*08/18/2017 21:01:16.6785] [*08/18/2017 21:01:16.6785] RES CFG Support wmi_service_bitmap 9778 [*08/18/2017 21:01:16.6785] [*08/18/2017 21:01:16.6785] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT [*08/18/2017 21:01:16.6785] ol_ath_service_ready_event: sw_cal_support_check_flag: 1 [*08/18/2017 21:01:16.7485] wmi_ready_event_rx: WMI UNIFIED READY event [*08/18/2017 21:01:16.7485] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0 [*08/18/2017 21:01:16.7585] ACS not enabled [*08/1
I've tried loading a new image via tftp and while it does reach out to the tftp server it eventually hangs and never transfers the file. I've also tried getting an image download to it using TeraTerm and Kermit but after 8 hours it was only at 29%. is there anyway to copy the image from USB while it's in Rommon? Or convert it back to LW and then upgrade it and then convert it back to ME?
11-14-2019 03:59 PM
11-14-2019 05:43 PM
I'll grab this in the morning and post. U-boot being the prompt when I hit esc during boot up correct?
11-14-2019 06:41 PM
11-15-2019 06:06 AM
pri by itself errored out:
(RNAQ-C7) # pri
Unknown command 'pri' - try 'help'
but here is the output from the 3 commands that start with pri:
(RNAQ-C7) # printenv
bootcmd=bootipq
bootdelay=5
bootfile=part.bin
ethact=eth0
ipaddr=192.168.1.1
machid=1260
serverip=192.168.1.254
stderr=serial
stdin=serial
stdout=serial
Environment size: 174/65532 bytes
(RNAQ-C7) # printmfgenv
mfg-tag = 0x43415049
mfg-rev = 0x1
mfg-type = 0x1
mfg-resv = 0x0
mfg-stime = 2017/04/11
PCA_PART_NUM_73 = 00-00000-00
PCA_REVISION_NUM = 02
PCB_SERIAL_NUM = myserial
FAB_PART_NUM = 00-0000-00
DEVIATION_NUM = 0
MAC_ADDR = mac_address:50
MAC_ADDR_BLOCK_SIZE = 8
R0_MAC_ADDR = mac_address:60
R0_MAC_ADDR_BLOCK_SIZE = 16
R1_MAC_ADDR = mac_address:70
R1_MAC_ADDR_BLOCK_SIZE = 16
PCA_ASSY_NUM_800 = 74-13149-02
PCA_REVISION_NUM_800 = 01
(RNAQ-C7) # printshenv
BAUDRATE=9600
BOOT=part1
ENABLE_BREAK=1
FACTORY_RESET=0
MANUAL_BOOT=0
MEMORY_DEBUG=0
Shared environment size: 98/16384 bytes, write counter: 12, active 1:1
(RNAQ-C7) #
11-15-2019 03:13 PM
11-18-2019 12:31 PM
Thanks. When i did this it still rebooting and booted off part 1. When I tried using "setshevnt BOOT part2" it seemed to save and boot off of part2, but it still hung but at a different stage. I waited about 15 minutes before seeing it crash again.
11-18-2019 12:54 PM
11-19-2019 08:14 AM
Here's the log. Booted up, hung after the last message for a few minutes and then cycled. At the moment just have a power injector connected to it w/ no dhcp available, but I didn't see any failure messages for dhcp.
~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.11.19 11:05:32 =~=~=~=~=~=~=~=~=~=~=~= U-Boot 2012.07 (btldr release 30) (Mar 03 2017 - 19:13:24) This product contains some software licensed under the "GNU General Public License, version 2" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU General Public License, version 2", available here: http://www.gnu.org/licenses/old-licenses/gpl-2.0.html DRAM: 1 GiB NAND (ONFI): Detected SPANSION S34MS02G2 [256 MiB] SF: Detected Macronix MX25U3235F [4 MiB] MFG data loaded Scanning shenv data blocks Total valid parts=4 Active shenv part[0:0], write_counter=13 PCI0 Link Intialized PCI1 Link Intialized Net: PHY ID = 0x4dd074, eth0 found AR8033 PHY PHY ID = 0x4dd074, eth1 found AR8033 PHY Valid I2C chip addresses: 51 52 AP 1832/1852 detected... Power Type: 802.3af POE or Others detected... Signature returns 0 BL signing verification success, continue to run... Auto boot mode, use bootipq directly Hit ESC key to stop autoboot: 5 4 3 2 1 0 Specified BOOT: part2 Booting from part2 Read 1024 bytes from volume part2 to 45000000 Read 37117838 bytes from volume part2 to 45000000 Signature returns 0 Image signing verification success, continue to run... Using machid 0x1260 from environment Starting image ... [01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d [01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point [01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc [01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=30M@1280M console=ttyHSL1,9600n8 activepart=part2 activeboot=0 wdgtriggered=0 [01/01/1970 00:00:00.1500] CPU1: Booted secondary processor [01/01/1970 00:00:00.2200] [01/01/1970 00:00:00.2200] +++ hydra_ap_gpio_value =3 [01/01/1970 00:00:24.3825] L2 Error detected! [01/01/1970 00:00:24.3825] L2ESR = 0x00010002 [01/01/1970 00:00:24.3825] L2ESYNR0 = 0x61008c83 [01/01/1970 00:00:24.3825] L2ESYNR1 = 0x10c0024c [01/01/1970 00:00:24.3825] L2EAR0 = 0x84018604 [01/01/1970 00:00:24.3825] L2EAR1 = 0x00000005 [01/01/1970 00:00:24.3825] CPU bitmap = 0x1 [01/01/1970 00:00:24.3825] SFAB: ID_REVISION_REG0 = 0x80000002 [01/01/1970 00:00:24.3825] SFAB: ID_REVISION_REG1 = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: CONFIGURATION_REG = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: ERROR_STATUS_REG_0 = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: ERROR_STATUS_REG_1 = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: ERROR_STATUS_REG_2 = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: ERROR_STATUS_REG_3 = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: ERROR_UPPER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] SFAB: ERROR_LOWER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ID_REVISION_REG0 = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ID_REVISION_REG1 = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: CONFIGURATION_REG = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ERROR_STATUS_REG_0 = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ERROR_STATUS_REG_1 = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ERROR_STATUS_REG_2 = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ERROR_STATUS_REG_3 = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ERROR_UPPER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] AFAB: ERROR_LOWER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ID_REVISION_REG0 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ID_REVISION_REG1 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: CONFIGURATION_REG = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ERROR_STATUS_REG_0 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ERROR_STATUS_REG_1 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ERROR_STATUS_REG_2 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ERROR_STATUS_REG_3 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ERROR_UPPER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_0: ERROR_LOWER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ID_REVISION_REG0 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ID_REVISION_REG1 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: CONFIGURATION_REG = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ERROR_STATUS_REG_0 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ERROR_STATUS_REG_1 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ERROR_STATUS_REG_2 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ERROR_STATUS_REG_3 = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ERROR_UPPER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] NSSFAB_1: ERROR_LOWER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ID_REVISION_REG0 = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ID_REVISION_REG1 = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: CONFIGURATION_REG = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ERROR_STATUS_REG_0 = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ERROR_STATUS_REG_1 = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ERROR_STATUS_REG_2 = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ERROR_STATUS_REG_3 = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ERROR_UPPER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] DAY_CFG: ERROR_LOWER_ADDR_REG = 0x00000000 [01/01/1970 00:00:24.3825] L2 master port slave error [01/01/1970 00:00:24.3825] ------------[ cut here ]------------ [01/01/1970 00:00:24.3825] WARNING: at /local/build/JENKINS/workspace/83MR1_repost_ME/c_smr1_repost_170317180855/router/linux-qca-3.4/arch/arm/mach-msm/cache_erp.c:449 msm_l2_erp_irq+0x200/0x298() [01/01/1970 00:00:24.3825] L2 master port error detected [01/01/1970 00:00:24.3825] Modules linked in: [01/01/1970 00:00:24.3825] Backtrace: [01/01/1970 00:00:24.3825] [<c001234c>] (dump_backtrace+0x0/0x114) from [<c03ac428>] (dump_stack+0x18/0x1c) [01/01/1970 00:00:24.3825] r6:000001c1 r5:c005a7a0 r4:ef343ce8 r3:c0781f0c [01/01/1970 00:00:24.3825] [<c03ac410>] (dump_stack+0x0/0x1c) from [<c005f32c>] (warn_slowpath_common.isra.3+0x50/0x60) [01/01/1970 00:00:24.3825] [<c005f2dc>] (warn_slowpath_common.isra.3+0x0/0x60) from [<c005f3c0>] (warn_slowpath_fmt+0x30/0x38) [01/01/1970 00:00:24.3825] r7:00000000 r6:c07fdad8 r5:00000000 r4:00010002 [01/01/1970 00:00:24.3825] [<c005f390>] (warn_slowpath_fmt+0x0/0x38) from [<c005a7a0>] (msm_l2_erp_irq+0x200/0x298) [01/01/1970 00:00:24.3825] r3:00000001 r2:c04a2be4 [01/01/1970 00:00:24.3825] [<c005a5a0>] (msm_l2_erp_irq+0x0/0x298) from [<c00a73f4>] (handle_irq_event_percpu+0x38/0x180) [01/01/1970 00:00:24.3825] [<c00a73bc>] (handle_irq_event_percpu+0x0/0x180) from [<c00a7594>] (handle_irq_event+0x58/0x78) [01/01/1970 00:00:24.3825] [<c00a753c>] (handle_irq_event+0x0/0x78) from [<c00aa5c0>] (handle_fasteoi_irq+0x120/0x184) [01/01/1970 00:00:24.3825] r6:00000001 r5:c0707b98 r4:c0707b40 r3:00000000 [01/01/1970 00:00:24.3825] [<c00aa4a0>] (handle_fasteoi_irq+0x0/0x184) from [<c00a6c64>] (generic_handle_irq+0x30/0x44) [01/01/1970 00:00:24.3825] r6:ef342000 r5:c07012c0 r4:c075c470 r3:c00aa4a0 [01/01/1970 00:00:24.3825] [<c00a6c34>] (generic_handle_irq+0x0/0x44) from [<c000ef98>] (handle_IRQ+0x84/0xb4) [01/01/1970 00:00:24.3825] [<c000ef14>] (handle_IRQ+0x0/0xb4) from [<c000860c>] (gic_handle_irq+0x94/0x108) [01/01/1970 00:00:24.3825] r8:00010000 r7:fa003000 r6:00000022 r5:c075b724 r4:00000022 [01/01/1970 00:00:24.3825] r3:00000012 [01/01/1970 00:00:24.3825] [<c0008578>] (gic_handle_irq+0x0/0x108) from [<c000e2c0>] (__irq_svc+0x40/0x50) [01/01/1970 00:00:24.3825] Exception stack(0xef343e10 to 0xef343e58) [01/01/1970 00:00:24.3825] 3e00: 00000000 00000000 00001000 f004a000 [01/01/1970 00:00:24.3825] 3e20: c07778c0 c085b3f0 c07778f4 c077f484 00000000 c079c980 00000000 ef343e64 [01/01/1970 00:00:24.3825] 3e40: 00000000 ef343e58 c026ad94 c026981c 60000113 ffffffff [01/01/1970 00:00:24.3825] [<c02697fc>] (platform_drv_probe+0x0/0x24) from [<c02684a8>] (driver_probe_device+0xdc/0x220) [01/01/1970 00:00:24.3825] [<c02683cc>] (driver_probe_device+0x0/0x220) from [<c026865c>] (__driver_attach+0x70/0x94) [01/01/1970 00:00:24.3825] r8:ef33e600 r7:c079c980 r6:c07778f4 r5:c077f484 r4:c07778c0 [01/01/1970 00:00:24.3825] r3:00000000 [01/01/1970 00:00:24.3825] [<c02685ec>] (__driver_attach+0x0/0x94) from [<c0266a88>] (bus_for_each_dev+0x54/0x94) [01/01/1970 00:00:24.3825] r6:c02685ec r5:c077f484 r4:00000000 r3:c02685ec [01/01/1970 00:00:24.3825] [<c0266a34>] (bus_for_each_dev+0x0/0x94) from [<c0267fc0>] (driver_attach+0x24/0x28) [01/01/1970 00:00:24.3825] r6:c078d640 r5:c077f484 r4:c060ea24 [01/01/1970 00:00:24.3825] [<c0267f9c>] (driver_attach+0x0/0x28) from [<c0267b70>] (bus_add_driver+0xe4/0x248) [01/01/1970 00:00:24.3825] [<c0267a8c>] (bus_add_driver+0x0/0x248) from [<c0268bb4>] (driver_register+0xa8/0x128) [01/01/1970 00:00:24.3825] [<c0268b0c>] (driver_register+0x0/0x128) from [<c0269b00>] (platform_driver_register+0x4c/0x60) [01/01/1970 00:00:24.3825] [<c0269ab4>] (platform_driver_register+0x0/0x60) from [<c060ea38>] (msm_ebi_erp_init+0x14/0x1c) [01/01/1970 00:00:24.3825] [<c060ea24>] (msm_ebi_erp_init+0x0/0x1c) from [<c0008760>] (do_one_initcall+0xb4/0x178) [01/01/1970 00:00:24.3825] [<c00086ac>] (do_one_initcall+0x0/0x178) from [<c0600b28>] (kernel_init+0x124/0x20c) [01/01/1970 00:00:24.3825] [<c0600a04>] (kernel_init+0x0/0x20c) from [<c0063ec4>] (do_exit+0x0/0x7cc) [01/01/1970 00:00:24.3825] ---[ end trace c566ba2a95728940 ]--- [01/01/1970 00:00:33.3297] buginf tty flushing thread started, ttyport=ef633e90 [01/01/1970 00:00:37.9683] msm_hsusb_host msm_hsusb_host: unable to find transceiver [01/01/1970 00:00:38.0982] watchdog: only one watchdog can use /dev/watchdog [01/01/1970 00:00:38.1682] watchdog: error registering /dev/watchdog (err=-16) [*01/01/1970 00:00:38.3682] buginf() enabled. Welcome to Cisco. Usage of this device is governed by Cisco's End User License Agreement, available at: http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html. Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. Cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. This product contains some software licensed under the "GNU General Public License, version 2" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU General Public License, version 2", available here: http://www.gnu.org/licenses/old-licenses/gpl-2.0.html This product contains some software licensed under the "GNU Library General Public License, version 2" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU Library General Public License, version 2", available here: http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html This product contains some software licensed under the "GNU Lesser General Public License, version 2.1" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser General Public License, version 2.1", available here: http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html This product contains some software licensed under the "GNU General Public License, version 3" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU General Public License, Version 3", available here: http://www.gnu.org/licenses/gpl.html. [*01/01/1970 00:00:38.3781] Made it into bootsh: Mar 17 2017 18:42:51 [*01/01/1970 00:00:38.3781] bootsh build T-5b864352eac5bfbb7162c6ba8bf112306a2378ae-g5b864352-vipendya [*01/01/1970 00:00:39.8777] /init: reading file /storage/config: No such file or directory [*01/01/1970 00:00:39.9077] init started: BusyBox v1.23.2 (2017-03-17 18:24:41 PDT) /usr/bin/serial_logincheck: reading file /storage/config: No such file or directory [*01/01/1970 00:00:41.5172] GCM-128 POST passed [*01/01/1970 00:00:41.5172] GCM-256 POST passed [*01/01/1970 00:00:41.7971] Active version: 8.3.112.0 [*01/01/1970 00:00:41.7971] Backup version: 8.4.100.0 Jan 1 00:00:41 FIPS[800]: *** shell: FIPS Mode = disabled *** [*01/01/1970 00:00:42.0170] AP1852I User Access Verification Username: [*01/01/1970 00:00:42.1170] nss_driver - Turbo Support 1 [*01/01/1970 00:00:42.1170] Supported Frequencies - 110Mhz 550Mhz 733Mhz [*01/01/1970 00:00:42.2269] [*01/01/1970 00:00:42.2269] phy_value=0: org="0x1000" phy_reg="0x1800" [*01/01/1970 00:00:42.6068] Current value of FACTORY_RESET=0 [*01/01/1970 00:00:42.6268] Last reload time: Aug 18 21:01:12 2017 [*08/18/2017 21:01:12.0000] Setting system time Fri Aug 18 21:01:12 UTC 2017 [*08/18/2017 21:01:12.0499] device wired0 entered promiscuous mode [*08/18/2017 21:01:12.1499] device wired1 entered promiscuous mode [*08/18/2017 21:01:12.5098] stile_lm_ft_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel. [*08/18/2017 21:01:12.5298] stile_lm_dp_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel. [*08/18/2017 21:01:12.5298] stile module dp init successfully [*08/18/2017 21:01:12.5298] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Oct 14 2016 at 11:20:56 [*08/18/2017 21:01:13.1296] [*08/18/2017 21:01:13.1396] boot 36 build T-5b864352eac5bfbb7162c6ba8bf112306a2378ae-g5b864352-vipendya board corsica mac ma:ad:re [*08/18/2017 21:01:13.1396] Module: mbedtls .text=0xbf000000 data=0xbf007e18 bss=0xbf008070 [*08/18/2017 21:01:13.1396] Module: aptrace .text=0xbf00c000 data=0xbf014040 bss=0xbf014448 [*08/18/2017 21:01:13.1396] Module: qca_nss_gmac .text=0xbf01b000 data=0xbf021ba4 bss=0xbf022064 [*08/18/2017 21:01:13.1396] Module: qca_nss_drv .text=0xbf02b000 data=0xbf042a40 bss=0xbf0437f0 [*08/18/2017 21:01:13.1396] Module: qca_nss_capwapmgr .text=0xbf05f000 data=0xbf062b8c bss=0xbf062ce0 [*08/18/2017 21:01:13.1396] Module: nssmgrctl .text=0xbf068000 data=0xbf069728 bss=0xbf069a4c [*08/18/2017 21:01:13.1396] Module: proclikefs .text=0xbf06f000 data= bss=0xbf06fb40 [*08/18/2017 21:01:13.1396] Module: stile_lm_ft .text= data= bss= [*08/18/2017 21:01:13.1396] Module: stile_lm_dp .text= data= bss= [*08/18/2017 21:01:13.1396] Module: bonding .text=0xbf95d000 data=0xbf96e664 bss=0xbf96ea90 [*08/18/2017 21:01:13.1396] Module: ipv6 .text=0xbf97b000 data=0xbf9ab900 bss=0xbf9ad1ac [*08/18/2017 21:01:13.1396] Module: lowmemorykiller .text=0xbf9c6000 data=0xbf9c62c0 bss=0xbf9c644c [*08/18/2017 21:01:13.1396] Module: qca_nss_profile_drv .text=0xbf9ca000 data=0xbf9cb324 bss=0xbf9cb498 [*08/18/2017 21:01:13.5395] Last reload reason : 0: unknown [*08/18/2017 21:01:15.1190] adf: module license 'Proprietary' taints kernel. [*08/18/2017 21:01:15.1190] asf: module license 'Proprietary' taints kernel. [*08/18/2017 21:01:15.1290] ath_hal: module license 'Proprietary' taints kernel. [*08/18/2017 21:01:15.1390] ath_dfs: module license 'Proprietary' taints kernel. [*08/18/2017 21:01:15.1390] ath_rate_atheros: module license 'Proprietary' taints kernel. [*08/18/2017 21:01:15.1390] ath_dev: module license 'Proprietary' taints kernel. [*08/18/2017 21:01:15.1790] [*08/18/2017 21:01:15.1790] __ol_ath_attach() Allocated scn c4c40480 [*08/18/2017 21:01:15.1890] Chip id: 0x9, chip version: 0x1000000 [*08/18/2017 21:01:15.1890] [*08/18/2017 21:01:15.1890] Target Version is 1000000 [*08/18/2017 21:01:15.1890] [*08/18/2017 21:01:15.1890] Flash Download Address c0000 [*08/18/2017 21:01:15.1890] ol_transfer_bin_file: flash data file defined [*08/18/2017 21:01:15.1890] Cal location [0]: 00000000 [*08/18/2017 21:01:15.1890] [*08/18/2017 21:01:15.1890] Wifi0 NAND FLASH Select OFFSET 0x1000 [*08/18/2017 21:01:15.2090] qc98xx_verify_checksum: flash checksum passed: 0xebce [*08/18/2017 21:01:15.2090] ol_transfer_bin_file 4053: Download Flash data len 12064 [*08/18/2017 21:01:15.2290] [*08/18/2017 21:01:15.2290] Board data initialized [*08/18/2017 21:01:15.2790] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660 [*08/18/2017 21:01:15.2790] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1 [*08/18/2017 21:01:15.2790] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin [*08/18/2017 21:01:15.3490] [*08/18/2017 21:01:15.3490] [Flash] : Ignore Module param [*08/18/2017 21:01:15.3589] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0 [*08/18/2017 21:01:15.3789] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin [*08/18/2017 21:01:16.4786] Startup Mode-0 set [*08/18/2017 21:01:16.4786] HTC Service:0x0300 ep:1 TX flow control disabled [*08/18/2017 21:01:16.4886] HTC Service:0x0100 ep:2 TX flow control disabled [*08/18/2017 21:01:16.4886] Firmware_Build_Number:106 [*08/18/2017 21:01:16.4886] host/RAM_fw Build Ver Mismatch: H:0x47, F:0x6A ! [*08/18/2017 21:01:16.4886] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffea [*08/18/2017 21:01:16.4886] [*08/18/2017 21:01:16.4886] RES CFG Support wmi_service_bitmap 9778 [*08/18/2017 21:01:16.4886] [*08/18/2017 21:01:16.4886] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT [*08/18/2
11-19-2019 01:14 PM
10-15-2020 06:49 PM
Is there any user resolution to this or is TAC the only answer? I have an 1832 now doing the same thing.
10-15-2020 07:56 PM
Same responses above -- Post the complete output to the command "pri".
10-16-2020 02:13 PM - edited 10-16-2020 02:26 PM
(RNAQ-C7) # pri
BOOT=part2
bootcmd=bootipq
bootdelay=5
bootfile=part.bin
ethact=eth0
fileaddr=44000000
filesize=2ADA000
ipaddr=192.168.1.1
machid=1260
stderr=serial
stdin=serial
stdout=serial
Environment size: 226/65532 bytes
mfg-rev = 0x1
mfg-type = 0x1
mfg-resv = 0x0
mfg-stime = 2016/11/05
PCB_SERIAL_NUM = KWC2045057A
DEVIATION_NUM = 0
MAC_ADDR = 00:59:DC:86:29:68
R0_MAC_ADDR = 00:59:DC:87:09:80
R1_MAC_ADDR = 00:59:DC:87:09:90
PCA_ASSY_NUM_800 = 74-104313-02
BAUDRATE=9600
BOOT=part1
ENABLE_BREAK=1
FACTORY_RESET=0
MANUAL_BOOT=0
MEMORY_DEBUG=0
Shared environment size: 98/16384 bytes, write counter: 7, active 1:0
10-16-2020 05:50 PM
setenv BOOT part1 saveenv
And then COLD reboot the AP (pull out the supply of power).
10-17-2020 05:31 AM
Thanks for replying. Tried that with the same results. Time to look at a replacement?
