Highlighted
Enthusiast
Cisco 1852i Unable to Boot
I had 2 1852i APs running mobility express that was running 8.4.100 code for a couple of years with no issue.  A few days ago one of the APs stopped checking in and I noticed it doesn't seem to be booting all the way.  if i get into the console i see it hangs and has the following errors:
Username: [*01/01/1970 00:00:36.5887] AP1852I
[*01/01/1970 00:00:36.6987] nss_driver - Turbo Support 1
[*01/01/1970 00:00:36.6987] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:36.7287] NSS firmware booted
[*01/01/1970 00:00:36.7587] NSS firmware booted
[*01/01/1970 00:00:36.8486]
[*01/01/1970 00:00:36.8486] phy_value=0: org="0x1000" phy_reg="0x1800"
[*01/01/1970 00:00:37.2285] Current value of FACTORY_RESET=0
[*01/01/1970 00:00:37.2485] Last reload time: Aug 18 21:01:12 2017
[*08/18/2017 21:01:12.0000] Setting system time Fri Aug 18 21:01:12 UTC 2017
[*08/18/2017 21:01:12.0599] device wired0 entered promiscuous mode
[*08/18/2017 21:01:12.1299] device wired1 entered promiscuous mode
[*08/18/2017 21:01:12.5298] stile module dp init successfully
[*08/18/2017 21:01:12.5298] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Nov  1 2016 at 16:53:57
[*08/18/2017 21:01:13.1696] miibus get eec91400!
[*08/18/2017 21:01:13.2096]
[*08/18/2017 21:01:13.2196] boot 10671 build T-ea744460b77c6aa805022a071636bbe91bfbef81-gea744460-vipendya board corsica mac 70:D3:79:E8:5F:50
[*08/18/2017 21:01:13.2196] Module: mbedtls  .text=0xbf000000        data=0xbf007e18        bss=0xbf008070
[*08/18/2017 21:01:13.2196] Module: aptrace  .text=0xbf00c000        data=0xbf014044        bss=0xbf014448
[*08/18/2017 21:01:13.2196] Module: led_module  .text=0xbf01b000        data=0xbf01b3cc        bss=0xbf01ba34
[*08/18/2017 21:01:13.2196] Module: qca_nss_gmac  .text=0xbf01f000        data=0xbf025be0        bss=0xbf0260a4
[*08/18/2017 21:01:13.2196] Module: qca_nss_drv  .text=0xbf02f000        data=0xbf04a050        bss=0xbf04ae00
[*08/18/2017 21:01:13.2196] Module: qca_nss_capwapmgr  .text=0xbf06b000        data=0xbf06fa88        bss=0xbf06fbd8
[*08/18/2017 21:01:13.2196] Module: nssmgrctl  .text=0xbf076000        data=0xbf077730        bss=0xbf077a54
[*08/18/2017 21:01:13.2196] Module: proclikefs  .text=0xbf07d000        data=        bss=0xbf07db40
[*08/18/2017 21:01:13.2196] Module: stile_lm_ft  .text=        data=        bss=
[*08/18/2017 21:01:13.2196] Module: stile_lm_dp  .text=        data=        bss=
[*08/18/2017 21:01:13.2196] Module: ipv6  .text=0xbf9c8000        data=0xbf9f8fc0        bss=0xbf9fa86c
[*08/18/2017 21:01:13.2196] Module: bonding  .text=0xbfa14000        data=0xbfa25644        bss=0xbfa25a70
[*08/18/2017 21:01:13.2196] Module: lowmemorykiller  .text=0xbfa32000        data=0xbfa322c0        bss=0xbfa3244c
[*08/18/2017 21:01:13.2196] Module: qca_nss_profile_drv  .text=0xbfa36000        data=0xbfa37320        bss=0xbfa37494
[*08/18/2017 21:01:13.2196] Module: ssdk_reg  .text=0xbfa3c000        data=        bss=0xbfa3c838
[*08/18/2017 21:01:13.6695] Last reload reason : 0: unknown
[*08/18/2017 21:01:13.8794] set led_patteren 12
[*08/18/2017 21:01:15.3090] __mm_init_module
[*08/18/2017 21:01:15.3589]
[*08/18/2017 21:01:15.3589] __ol_ath_attach() Allocated scn edf80480
[*08/18/2017 21:01:15.3689] ol_ath_attach interface_id 0
[*08/18/2017 21:01:15.3689] Chip id: 0x9, chip version: 0x1000000
[*08/18/2017 21:01:15.3689]  Target Version is 1000000
[*08/18/2017 21:01:15.3689]  Flash Download Address  c0000
[*08/18/2017 21:01:15.3689] ol_transfer_bin_file: flash data file defined
[*08/18/2017 21:01:15.3689] Cal location [0]: 00000000
[*08/18/2017 21:01:15.3689]  Wifi0 NAND FLASH Select OFFSET 0x1000
[*08/18/2017 21:01:15.3889] qc98xx_verify_checksum: flash checksum passed: 0xebce
[*08/18/2017 21:01:15.3889] ol_transfer_bin_file 3754: Download Flash data len 12064
[*08/18/2017 21:01:15.4089]
[*08/18/2017 21:01:15.4089]  Board data initialized
[*08/18/2017 21:01:15.4589] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*08/18/2017 21:01:15.4589] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*08/18/2017 21:01:15.4589] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*08/18/2017 21:01:15.5389]
[*08/18/2017 21:01:15.5389]  [Flash] : Ignore Module param
[*08/18/2017 21:01:15.5389] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*08/18/2017 21:01:15.5689] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*08/18/2017 21:01:16.6685] HTC Rx: insufficient length, got:4 expected =8
[*08/18/2017 21:01:16.6785] Startup Mode-0 set
[*08/18/2017 21:01:16.6785] HTC Service:0x0300 ep:1 TX flow control disabled
[*08/18/2017 21:01:16.6785] HTC Service:0x0100 ep:2 TX flow control disabled
[*08/18/2017 21:01:16.6785] Firmware_Build_Number:70
[*08/18/2017 21:01:16.6785] num_rf_chain:0x00000004  ht_cap_info:0x0000185b  vht_cap_info:0x339a79b2  vht_supp_mcs:0x0000ffaa
[*08/18/2017 21:01:16.6785]  RES CFG Support wmi_service_bitmap 9778
[*08/18/2017 21:01:16.6785]  Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*08/18/2017 21:01:16.6785] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*08/18/2017 21:01:16.7485] wmi_ready_event_rx:  WMI UNIFIED READY event
[*08/18/2017 21:01:16.7485] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*08/18/2017 21:01:16.7585] ACS not enabled
[*08/1
I've tried loading a new image via tftp and while it does reach out to the tftp server it eventually hangs and never transfers the file.  I've also tried getting an image download to it using TeraTerm and Kermit but after 8 hours it was only at 29%.  is there anyway to copy the image from USB while it's in Rommon? Or convert it back to LW and then upgrade it and then convert it back to ME?
17 REPLIES 17
Highlighted
Hall of Fame Community Legend
Post the entire boot-up of the AP so we can see what it is doing.
Highlighted
Here's the boot-up:
U-Boot 2012.07 (btldr release 24) (Apr 06 2016 - 10:42:24)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM:  1 GiB
NAND (ONFI): Detected SPANSION S34MS02G2 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:0], write_counter=7
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3af POE or Others detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot:  5  4  3  2  1  0
Specified BOOT: part1
Booting from part1
Read 1024 bytes from volume part1 to 45000000
Read 34908398 bytes from volume part1 to 45000000
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=30M@1280M console=ttyHSL1,9600n8 activepart=part1 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:21.4234] buginf tty flushing thread started, ttyport=ef4a6090
[01/01/1970 00:00:26.0420] msm_hsusb_host msm_hsusb_host: unable to find transceiver
[01/01/1970 00:00:26.1620] watchdog: only one watchdog can use /dev/watchdog
[01/01/1970 00:00:26.2319] watchdog: error registering /dev/watchdog (err=-16)
[*01/01/1970 00:00:26.4319] buginf() enabled.
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
             Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
            Cisco Systems, Inc.
            170 West Tasman Drive
            San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
[*01/01/1970 00:00:26.4419] Made it into bootsh: Jul 29 2016 09:10:41
[*01/01/1970 00:00:26.4419] bootsh build T-2d1c1ce438f2cb0c719147574ed938c13b0c6a4a-g2d1c1ce4-vipendya
[*01/01/1970 00:00:27.9814]
init started: BusyBox v1.20.2 (2016-07-29 08:32:20 PDT)
User Access Verification
Username: [*01/01/1970 00:00:29.6709] Active version: 8.3.102.0
[*01/01/1970 00:00:29.6709] Backup version: 0.0.0.0
[*01/01/1970 00:00:29.8108] AP1852I
[*01/01/1970 00:00:29.9008] nss_driver - Turbo Support 1
[*01/01/1970 00:00:29.9008] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:30.0108]
[*01/01/1970 00:00:30.0108] phy_value=0: org="0x1000" phy_reg="0x1800"
[*01/01/1970 00:00:30.3606] Current value of FACTORY_RESET=0
[*01/01/1970 00:00:30.3706] Last reload time: Sep 29 18:18:43 2020
[*09/29/2020 18:18:43.0000] Setting system time Tue Sep 29 18:18:43 UTC 2020
[*09/29/2020 18:18:43.0799] device wired0 entered promiscuous mode
[*09/29/2020 18:18:43.1499] device wired1 entered promiscuous mode
[*09/29/2020 18:18:43.1499] phy_value=0: org="0x1800" phy_reg="0x1800"
[*09/29/2020 18:18:43.4599] stile_lm_ft_corsica: module license [09/29/2020 18:18:43.4798] stile module dp init successfully
[09/29/2020 18:18:43.5798] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Apr 22 2016 at 10:38:42
'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[*09/29/2020 18:18:43.4798] stile_lm_dp_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[*09/29/2020 18:18:44.0697]
[*09/29/2020 18:18:44.0797] boot 25459 build T-2d1c1ce438f2cb0c719147574ed938c13b0c6a4a-g2d1c1ce4-vipendya board corsica mac 00:59:DC:86:29:68
[*09/29/2020 18:18:44.0797] Module: qca_nss_gmac  .text=0xbf000000        data=0xbf006b70        bss=0xbf007030
[*09/29/2020 18:18:44.0797] Module: qca_nss_drv  .text=0xbf010000        data=0xbf0277b0        bss=0xbf028560
[*09/29/2020 18:18:44.0797] Module: qca_nss_capwapmgr  .text=0xbf044000        data=0xbf047ba8        bss=0xbf047cf8
[*09/29/2020 18:18:44.0797] Module: nssmgrctl  .text=0xbf04d000        data=0xbf04e728        bss=0xbf04ea4c
[*09/29/2020 18:18:44.0797] Module: proclikefs  .text=0xbf054000        data=        bss=0xbf054b40
[*09/29/2020 18:18:44.0797] Module: stile_lm_ft  .text=        data=        bss=
[*09/29/2020 18:18:44.0797] Module: stile_lm_dp  .text=        data=        bss=
[*09/29/2020 18:18:44.0797] Module: qca_nss_profile_drv  .text=0xbf8d1000        data=0xbf8d2324        bss=0xbf8d2498
[*09/29/2020 18:18:44.4296] Last reload reason : 0: unknown
[*09/29/2020 18:18:45.6792] adf: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.6892] asf: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.6892] ath_hal: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.6992] ath_dfs: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.6992] ath_rate_atheros: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7092] ath_dev: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7391]
[*09/29/2020 18:18:45.7391] __ol_ath_attach() Allocated scn c4bc0480
[*09/29/2020 18:18:45.7491] Chip id: 0x9, chip version: 0x1000000
[*09/29/2020 18:18:45.7491]  Target Version is 1000000
[*09/29/2020 18:18:45.7491]  Flash Download Address  c0000
[*09/29/2020 18:18:45.7491] ol_transfer_bin_file: flash data file defined
[*09/29/2020 18:18:45.7491] Cal location [0]: 00000000
[*09/29/2020 18:18:45.7491]  Wifi0 NAND FLASH Select OFFSET 0x1000
[*09/29/2020 18:18:45.7691] qc98xx_verify_checksum: flash checksum passed: 0x1b74
[*09/29/2020 18:18:45.7691] ol_transfer_bin_file 4017: Download Flash data len 12064
[*09/29/2020 18:18:45.7991]
[*09/29/2020 18:18:45.7991]  Board data initialized
[*09/29/2020 18:18:45.8391] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*09/29/2020 18:18:45.8391] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*09/29/2020 18:18:45.8391] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*09/29/2020 18:18:45.9091]
[*09/29/2020 18:18:45.9091]  [Flash] : Ignore Module param
[*09/29/2020 18:18:45.9191] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/29/2020 18:18:45.9391] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*09/29/2020 18:18:47.0387] Startup Mode-0 set
[*09/29/2020 18:18:47.0387] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/29/2020 18:18:47.0387] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/29/2020 18:18:47.0487] Firmware_Build_Number:84
[*09/29/2020 18:18:47.0487] host/RAM_fw Build Ver Mismatch: H:0x47, F:0x54 !
[*09/29/2020 18:18:47.0487] num_rf_chain:0x00000004  ht_cap_info:0x0000185b  vht_cap_info:0x339a79b2  vht_supp_mcs:0x0000ffea
[*09/29/2020 18:18:47.0487]  RES CFG Support wmi_service_bitmap 9778
[*09/29/2020 18:18:47.0487]  Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*09/29/2020 18:18:47.0487] Mesh Supported
[*09/29/2020 18:18:47.1287] wmi_ready_event_rx:  WMI UNIFIED READY event
[*09/29/2020 18:18:47.1287] ACS not enabled
[*09/29/2020 18:18:47.1287] ol_ath_thermal_mitigation_attach: --
[*09/29/2020 18:18:47.1287] __ol_ath_attach() Allocated scn c4580480
[*09/29/2020 18:18:47.1387] Chip id: 0x9, chip version: 0x1000000
[*09/29/2020 18:18:47.1387]  Target Version is 1000000
[*09/29/2020 18:18:47.1387]  Flash Download Address  c0000
[*09/29/2020 18:18:47.1387] ol_transfer_bin_file: flash data file defined
[*09/29/2020 18:18:47.1387] Cal location [1]: 00004000
[*09/29/2020 18:18:47.1387]  wifi1 NAND FLASH Select OFFSET 0x5000
[*09/29/2020 18:18:47.1587] qc98xx_verify_checksum: flash checksum passed: 0x2e74
[*09/29/2020 18:18:47.1587] ol_transfer_bin_file 4017: Download Flash data len 12064
[*09/29/2020 18:18:47.1787]
[*09/29/2020 18:18:47.1787]  Board data initialized
[*09/29/2020 18:18:47.2287] ol_ath_download_firmware :First OTP download and Execute is good address:0x9c00 return param 4660
[*09/29/2020 18:18:47.2287] ol_ath_download_firmware:##Board Id 7 , CHIP Id 1
[*09/29/2020 18:18:47.2287] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin
[*09/29/2020 18:18:47.2987]
[*09/29/2020 18:18:47.2987]  [Flash] : Ignore Module param
[*09/29/2020 18:18:47.3087] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/29/2020 18:18:47.3286] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*09/29/2020 18:18:48.0384] FWLOG: [35118] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.0384] FWLOG: [35119] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.0384] FWLOG: [35119] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.0384] FWLOG: [35119] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.4183] Startup Mode-0 set
[*09/29/2020 18:18:48.4183] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/29/2020 18:18:48.4283] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/29/2020 18:18:48.4283] Firmware_Build_Number:84
[*09/29/2020 18:18:48.4283] host/RAM_fw Build Ver Mismatch: H:0x47, F:0x54 !
[*09/29/2020 18:18:48.4283] num_rf_chain:0x00000004  ht_cap_info:0x0000185b  vht_cap_info:0x339b79b2  vht_supp_mcs:0x0000ffea
[*09/29/2020 18:18:48.4283]  RES CFG Support wmi_service_bitmap 9778
[*09/29/2020 18:18:48.4283]  Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*09/29/2020 18:18:48.4283] Mesh Supported
[*09/29/2020 18:18:50.6176] pid 1460's current affinity mask: 3
[*09/29/2020 18:18:50.6176] pid 1460's new affinity mask: 1
[*09/29/2020 18:18:58.4352] WMI is not ready
  [09/29/2020 18:18:58.4452] L2 Error detected!
[09/29/2020 18:18:58.4452] 	L2ESR    = 0x00010001
[09/29/2020 18:18:58.4452] 	L2ESYNR0 = 0x12005690
[09/29/2020 18:18:58.4452] 	L2ESYNR1 = 0x00e77b7e
[09/29/2020 18:18:58.4452] 	L2EAR0   = 0x00001000
[09/29/2020 18:18:58.4452] 	L2EAR1   = 0x00000000
[09/29/2020 18:18:58.4452] 	CPU bitmap = 0x1
DRAM:  1 GiB
MFG data loaded
Total valid parts=4
Net:
QCA crashdump found.No WDOG context, ignored.
Cleared for a clean reboot ...resetting ...
DRAM:  1 GiB
MFG data loaded
Total valid parts=4
Net:
Signature returns 0
Booting from part1
Signature returns 0
Starting image ...
[01/01/1970 00:00:21.4134] buginf tty flushing thread started, ttyport=ef661890
[01/01/1970 00:00:26.0220] msm_hsusb_host msm_hsusb_host: unable to find transceiver
[01/01/1970 00:00:26.1420] watchdog: only one watchdog can use /dev/watchdog
[01/01/1970 00:00:26.2219] watchdog: error registering /dev/watchdog (err=-16)
[*01/01/1970 00:00:26.4019] buginf() enabled.
Welcome to Cisco.
available at:
            Cisco Systems, Inc.
export@cisco.com.
[*01/01/1970 00:00:26.4119] Made it into bootsh: Jul 29 2016 09:10:41
[*01/01/1970 00:00:26.4119] bootsh build T-2d1c1ce438f2cb0c719147574ed938c13b0c6a4a-g2d1c1ce4-vipendya
Username: [*01/01/1970 00:00:29.6609] Active version: 8.3.102.0
[*01/01/1970 00:00:29.6609] Backup version: 0.0.0.0
[*01/01/1970 00:00:29.8008] AP1852I
[*01/01/1970 00:00:29.8908] nss_driver - Turbo Support 1
[*01/01/1970 00:00:29.8908] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*01/01/1970 00:00:29.9908]
[*01/01/1970 00:00:29.9908] phy_value=0: org="0x1000" phy_reg="0x1800"
[*09/29/2020 18:18:43.0599] device wired0 entered promiscuous mode
[*09/29/2020 18:18:43.1399] device wired1 entered promiscuous mode
[*09/29/2020 18:18:43.1399] phy_value=0: org="0x1800" phy_reg="0x1800"
[*09/29/2020 18:18:43.5198] stile_lm_ft_corsica: module license [09/29/2020 18:18:43.5398] stile module dp init successfully
[09/29/2020 18:18:43.6398] NBAR Label:BLD_MCP_DEV_LATEST_20150424_123021 NBAR VERSION:module build date: Apr 22 2016 at 10:38:42
[*09/29/2020 18:18:43.5398] stile_lm_dp_corsica: module license 'Copyright (c) 2014-2015 by cisco Systems, Inc.' taints kernel.
[*09/29/2020 18:18:44.1296]
[*09/29/2020 18:18:44.1296] boot 25460 build T-2d1c1ce438f2cb0c719147574ed938c13b0c6a4a-g2d1c1ce4-vipendya board corsica mac 00:59:DC:86:29:68
[*09/29/2020 18:18:44.1396] Module: qca_nss_gmac  .text=0xbf000000        data=0xbf006b70        bss=0xbf007030
[*09/29/2020 18:18:44.1396] Module: qca_nss_drv  .text=0xbf010000        data=0xbf0277b0        bss=0xbf028560
[*09/29/2020 18:18:44.1396] Module: qca_nss_capwapmgr  .text=0xbf044000        data=0xbf047ba8        bss=0xbf047cf8
[*09/29/2020 18:18:44.1396] Module: nssmgrctl  .text=0xbf04d000        data=0xbf04e728        bss=0xbf04ea4c
[*09/29/2020 18:18:44.1396] Module: proclikefs  .text=0xbf054000        data=        bss=0xbf054b40
[*09/29/2020 18:18:44.1396] Module: stile_lm_ft  .text=        data=        bss=
[*09/29/2020 18:18:44.1396] Module: stile_lm_dp  .text=        data=        bss=
[*09/29/2020 18:18:44.1396] Module: qca_nss_profile_drv  .text=0xbf8d1000        data=0xbf8d2324        bss=0xbf8d2498
[*09/29/2020 18:18:44.4495] Last reload reason : 0: unknown
[*09/29/2020 18:18:45.7092] adf: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7092] asf: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7191] ath_hal: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7291] ath_dfs: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7291] ath_rate_atheros: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7391] ath_dev: module license 'Proprietary' taints kernel.
[*09/29/2020 18:18:45.7591]
[*09/29/2020 18:18:45.7591] __ol_ath_attach() Allocated scn c4b40480
[*09/29/2020 18:18:45.7791] Chip id: 0x9, chip version: 0x1000000
[*09/29/2020 18:18:45.7791]  Target Version is 1000000
[*09/29/2020 18:18:45.7791]  Flash Download Address  c0000
[*09/29/2020 18:18:45.7791] ol_transfer_bin_file: flash data file defined
[*09/29/2020 18:18:45.7791] Cal location [0]: 00000000
[*09/29/2020 18:18:45.7791]  Wifi0 NAND FLASH Select OFFSET 0x1000
[*09/29/2020 18:18:45.7991] qc98xx_verify_checksum: flash checksum passed: 0x1b74
[*09/29/2020 18:18:45.7991] ol_transfer_bin_file 4017: Download Flash data len 12064
[*09/29/2020 18:18:45.8191]
[*09/29/2020 18:18:45.8191]  Board data initialized
[*09/29/2020 18:18:45.8591] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*09/29/2020 18:18:45.8591] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*09/29/2020 18:18:45.8591] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*09/29/2020 18:18:45.9291]
[*09/29/2020 18:18:45.9291]  [Flash] : Ignore Module param
[*09/29/2020 18:18:45.9391] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/29/2020 18:18:45.9691] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*09/29/2020 18:18:47.0787] Startup Mode-0 set
[*09/29/2020 18:18:47.0787] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/29/2020 18:18:47.0787] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/29/2020 18:18:47.0787] Firmware_Build_Number:84
[*09/29/2020 18:18:47.0787] host/RAM_fw Build Ver Mismatch: H:0x47, F:0x54 !
[*09/29/2020 18:18:47.0787] num_rf_chain:0x00000004  ht_cap_info:0x0000185b  vht_cap_info:0x339a79b2  vht_supp_mcs:0x0000ffea
[*09/29/2020 18:18:47.0787]  RES CFG Support wmi_service_bitmap 9778
[*09/29/2020 18:18:47.0787]  Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*09/29/2020 18:18:47.0787] Mesh Supported
[*09/29/2020 18:18:47.1387] wmi_ready_event_rx:  WMI UNIFIED READY event
[*09/29/2020 18:18:47.1487] ACS not enabled
[*09/29/2020 18:18:47.1487] ol_ath_thermal_mitigation_attach: --
[*09/29/2020 18:18:47.1487] __ol_ath_attach() Allocated scn c4540480
[*09/29/2020 18:18:47.1687] Chip id: 0x9, chip version: 0x1000000
[*09/29/2020 18:18:47.1687]  Target Version is 1000000
[*09/29/2020 18:18:47.1687]  Flash Download Address  c0000
[*09/29/2020 18:18:47.1687] ol_transfer_bin_file: flash data file defined
[*09/29/2020 18:18:47.1687] Cal location [1]: 00004000
[*09/29/2020 18:18:47.1687]  wifi1 NAND FLASH Select OFFSET 0x5000
[*09/29/2020 18:18:47.1887] qc98xx_verify_checksum: flash checksum passed: 0x2e74
[*09/29/2020 18:18:47.1887] ol_transfer_bin_file 4017: Download Flash data len 12064
[*09/29/2020 18:18:47.2087]
[*09/29/2020 18:18:47.2087]  Board data initialized
[*09/29/2020 18:18:47.2487] ol_ath_download_firmware :First OTP download and Execute is good address:0x9c00 return param 4660
[*09/29/2020 18:18:47.2487] ol_ath_download_firmware:##Board Id 7 , CHIP Id 1
[*09/29/2020 18:18:47.2487] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin
[*09/29/2020 18:18:47.3186]
[*09/29/2020 18:18:47.3186]  [Flash] : Ignore Module param
[*09/29/2020 18:18:47.3286] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/29/2020 18:18:47.3586] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*09/29/2020 18:18:48.0684] FWLOG: [35142] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.0684] FWLOG: [35142] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.0684] FWLOG: [35142] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.0684] FWLOG: [35142] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/29/2020 18:18:48.4483] Startup Mode-0 set
[*09/29/2020 18:18:48.4483] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/29/2020 18:18:48.4483] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/29/2020 18:18:48.4483] Firmware_Build_Number:84
[*09/29/2020 18:18:48.4483] host/RAM_fw Build Ver Mismatch: H:0x47, F:0x54 !
[*09/29/2020 18:18:48.4483] num_rf_chain:0x00000004  ht_cap_info:0x0000185b  vht_cap_info:0x339b79b2  vht_supp_mcs:0x0000ffea
[*09/29/2020 18:18:48.4483]  RES CFG Support wmi_service_bitmap 9778
[*09/29/2020 18:18:48.4483]  Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 10 to TGT
[*09/29/2020 18:18:48.4483] Mesh Supported
[*09/29/2020 18:18:50.6376] pid 1458's current affinity mask: 3
[*09/29/2020 18:18:50.6376] pid 1458's new affinity mask: 1
[09/29/2020 18:18:58.4652] L2 Error detected!
[09/29/2020 18:18:58.4652] 	L2ESR    = 0x00010001
[09/29/2020 18:18:58.4652] 	L2ESYNR0 = 0x12005690
[09/29/2020 18:18:58.4652] 	L2ESYNR1 = 0x00e77b7e
[09/29/2020 18:18:58.4652] 	L2EAR0   = 0x00001000
[09/29/2020 18:18:58.4652] 	L2EAR1   = 0x00000000
[09/29/2020 18:18:58.4652] 	CPU bitmap = 0x1
Highlighted
Contact Cisco TAC and arrange for an RMA.
Content for Community-Ad
