Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
165
Highlighted
Beginner
Cisco 5520 - CTS
Hi All,
Having issues joining a 5520 WLC(SSO) into an ISE 2.6 (CTS) environment, for some reason the WLC can not retrieve environmental data or SGT info. Latest version of code running on the WLC. Looks to be related to CoA not being excepted by the WLC from ISE?
Using 9500/9200 switch platform environment and these work fine with CTS.
Cheers!
3 REPLIES 3
Highlighted
Collaborator
Re: Cisco 5520 - CTS
Highlighted
Beginner
Turned out to be a known BUG - Patch fixed issue, thanks for the reply.
Highlighted
Contributor
bug ID ?
-Rate helpful posts-
Content for Community-Ad
Cisco COVID-19 Survey
