We are trying to setup an outdoor wireless network with 1532I access point in autonomous mode. We created a 2.4Ghz network with WPA ver 2 and AES encryption.
The problem is that some devices stay connected but can't access event to network (LAN or WAN). There are some other devices that stay connected without any problem. There is no warning or error in the event logs.
The initial setup 1532I access point powered by a 2960G POE switch.
In a trying to identify the problem I setuped another access point in my local home powered but a power injector and I got the samew problem: My phone (Samsung S8) showing and icone of network with an exclamation point. My raspberry pi work perfectly and is never disconnected.
Thanks.
Configuration:
Building configuration... Current configuration : 2410 bytes ! ! Last configuration change at 09:54:24 -0500 Tue Mar 2 1993 ! NVRAM config last updated at 07:22:10 -0400 Sat Sep 14 2019 ! NVRAM config last updated at 07:22:10 -0400 Sat Sep 14 2019 version 15.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname ap ! ! logging rate-limit console 9 enable secret 5 $1$g8pP$564596m8m9cP32bRORCGi/ ! no aaa new-model clock timezone -0500 -5 0 clock summer-time -0400 recurring no ip source-route no ip cef ! ! ! ! dot11 pause-time 100 dot11 syslog ! dot11 ssid CDL authentication open authentication key-management wpa version 2 guest-mode wpa-psk ascii 7 101A5841564543595F557F ! dot11 ssid CDL_5ghz authentication open authentication key-management wpa version 2 guest-mode wpa-psk ascii 7 0050425E57095A545C7019 ! ! ! no ipv6 cef ! ! username Cisco password 7 0802455D0A16 ! ! ! bridge irb ! ! ! interface Dot11Radio0 no ip address ! encryption mode ciphers aes-ccm ! ssid CDL ! antenna gain 0 packet retries 128 drop-packet station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio1 no ip address ! encryption mode ciphers aes-ccm ! ssid CDL_5ghz ! antenna gain 0 peakdetect dfs band 3 block channel dfs station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface GigabitEthernet0 no ip address duplex auto speed auto bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface GigabitEthernet1 no ip address duplex auto speed auto bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface BVI1 mac-address 78da.6e60.9978 ip address 192.168.2.190 255.255.255.0 ipv6 address dhcp ipv6 address autoconfig ipv6 enable ! ip default-gateway 192.168.2.1 ip forward-protocol nd ip http server no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 login local transport input all ! sntp broadcast client end
If one device is working fine, it´s hard to believe the problem is configurarion issue. Exclamation mark usually means the device tried to validate internet access and failed.
Verify if device has an IP address, if it can ping the gateway. If true, you should be good and the problem can be a bug.
If not, some troubleshooting should be done!
-If I helped you somehow, please, rate it as useful.-
I resolve the problem with the gateway there was a probleme the the fibre converter. So I plug the acces point this way:
[Internet] - Modem - Router - 2960G POE+ switch - Access point
It seems, now that the network shutdown down for some second than comeback.
The access point has the lastest firmware15.3(3)JJ.
I also got cisco 1140 plug with the same setup. It work perfectly.
