01-07-2013 01:36 AM - edited 07-03-2021 11:18 PM
I have 2 Air-Lap1242 that wont save their config after reboot.
They are managed by a WLC (4404) and it all seems pretty fine and dandy, but when i reboot them, they dont want to save anything.
I am setting them up as bridges (mesh), and it works until i reboot them, then I have to do it all over again.
Using CLI to type in "write mem" or "copy running-config startup-config" only results in:
"Building configuration... [OK] ->
NVRAM Verification Failed "
Anyone who has any sort of solutions to this? Ive tried to google hard on the subject, but didnt get any wiser.
01-07-2013 01:40 AM
You don't make configurations on the WAP. That defeats the purpose of controller-based access points.
You make your configuration using the WLC.
01-07-2013 01:52 AM
I am aware of that, but it seems that the WLC dont save the config it pushes to the ap.
Thats why i tried CLI also, but with no luck.
01-07-2013 01:53 AM
What do you mean "WLC dont save the config"??? What are you trying to configure? How did you verify the WLC isn't saving the config? Did you click "Apply" and then "Save Configuration"?
01-07-2013 02:05 AM
When the AP joins the controller, I set up the settings for its intended use, in this example a bridge. (one ap as root, one as mesh).
After everything is filled out, i reload the ap's and all is good. Then i fill in the "mesh"-folder that appears after reload and reload the Ap and once again all is saved on the Ap. If I disconnect the power to them, both Ap's return to factory default.
01-07-2013 02:13 AM
What firmware is your 4400 running?
01-07-2013 02:15 AM
It is running 7.0.230.0.
01-08-2013 01:44 PM
I've used that firmware before and I've never seen this issue. Can you try upgrading your firmware to 7.0.235.3, please?
01-09-2013 02:12 AM
How APs are getting IP address? Through DHCP or Static. Have you confirmed AP is Joining to Controller and Broadcasting SSID. In the Joining time you can connect to APs Console and take the log of Joining process.
