Cisco AP 2504 running 7.4.110.0 image adding on Cisco AP 1852
KEVIN MCCOY
i have a Controller 2504 running 7.4.110.0 (default) (active) image and would like to add in some additional AP's (1852 model) - will it work with this image or do i need to upgrade to the latest image.
I will update to the latest image but its risky in Q4 and will be doing it in Q1 of 2018 but wanted to see if there will be complications with the new AP
 Try to follow this doc and let me know if you need something in particular.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_0100.html
-If I helped you somehow, please, rate it as useful.-
Hi @KEVIN MCCOY
Unfortunately is not possible. 1852 is supported on version 8.1.111.0 and newer only. So, you need to upgrade your WLC to at least 8.1.111.0.
thanks for the reply - is there any step by step process to upgrade that anyone can point me to?
