Cisco ISE web auth Splash page
brettlarkins
Was wondering if the splash page offered by Cisco ISE can be customized, or if it's necessary to redirect to an External server?
Currently using a downloaded web auth pass-through splash page setup for guest access on a 5508 WLC, but have been asked to move this feature off the WLC and onto the ISE and then customize the page with company logo's and a couple graphics.
Is this possible?
Thanks in advance...
Yes, but you will definitely need ISE 1.3. When creating the guest portal in ISE you would select the "Hotspot Guest Portal" option. This allows guest users to just agree to an AUP (Acceptable Use Policy) and then get Wi-Fi access.
And yes, you can also perform posture assessment:
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-software/118741-configure-ise-00.html#anc9
Thank you for rating helpful posts!
5 Replies 5
nspasov
Yes, you can customize the guest page on ISE. I would recommend going with v1.3 since that version offers the easiest method of customizing the portal. Prior to 1.2 you had to manually create HTML files, upload them and link them to the login flow process.
Great info... thanks!
And would I be able to create just a pass-through splash page where users only need to accept an acceptable use policy and not enter any username/password or do any posturing?
Just wanted to follow up and say thanks again... the link you provided for the walk-through is very helpful!
No problem! Glad I could help! :)
