410
Highlighted
Beginner
Cisco Prime 1.2 Licensing question
Hi all,
I am try to design a wireless solution where we will use WLC, MSE, ACS and we want to hace map location of the ap.
It is a new solution, no a upgrading
For the use of map and location in Cisco Prime wich license is required?, just with the lifecycle can i do?
This solution is for a 120 ap´s, i list the license what i think that i need
R-PI12-K9
R-PI12-BASE-K9
L-PI12-LF-100
L-PI12-LF-50
I hope be clear
Sebastian
Everyone's tags (4)
1 REPLY 1
Enthusiast
I beleive that with life cycle you should be able to do maps, although you will obviously need a base as well.
Also, I don't beleive that you can get ACS anymore, so you will be looking at ISE instead.
Content for Community-Ad
July's Community Spotlight Awards
