430
Highlighted
Beginner
Cisco Prime 1.2 - same WLANID accross all controllers
does anyone know how to achieve to have same WLAN IDs accross all controllers using a WLC Template?
There is no possibility to enter the ID directly.
When I create a WLAN with the same name on WLC before it's not being overwritten and SNMP to device fails.
Thanks for any hints.
K.
Everyone's tags (5)
3 REPLIES 3
You can use a CLI template from PI 1.2. It would be the same procedure/commands as configuring the WLAN from the CLI of the controller but using PI to keep them uniform across the WLC's.
It can be found from Design --> Configuration templates --> Controller --> CLI --> General.
Ram
Beginner
Yes, that's can be also the way, but here I have worries if it will also work for older 4404 WLCs.
However I would welcome if the wlan ID could be added to the PI templates.
K.
Beginner
I would also like to see the capability to specify the WLAN ID without having to resort to a CLI configuration template.
Content for Community-Ad
August's Community Spotlight Awards
