10-23-2012 02:02 PM - edited 07-03-2021 10:54 PM
does anyone know how to achieve to have same WLAN IDs accross all controllers using a WLC Template?
There is no possibility to enter the ID directly.
When I create a WLAN with the same name on WLC before it's not being overwritten and SNMP to device fails.
Thanks for any hints.
K.
10-24-2012 05:12 PM
You can use a CLI template from PI 1.2. It would be the same procedure/commands as configuring the WLAN from the CLI of the controller but using PI to keep them uniform across the WLC's.
It can be found from Design --> Configuration templates --> Controller --> CLI --> General.
Ram
10-25-2012 01:28 AM
Yes, that's can be also the way, but here I have worries if it will also work for older 4404 WLCs.
However I would welcome if the wlan ID could be added to the PI templates.
K.
02-07-2013 12:02 PM
I would also like to see the capability to specify the WLAN ID without having to resort to a CLI configuration template.
