Cisco Prime Actions logging
codflanglers
Anyone know if it is possible to see what actions a particular user has done in the logs?
Typically I removed some APs from CPI this morning and now I'm being asked for the MAC addresses of these APs. I was hoping that as I deleted them from CPI it would show this in a log somewhere.
Any ideas where? I've looked at things like the inventory and localhost_access log file but it doesn't seem to be in there.
M. Wisely
Level 4
Level 4
Have you run the change audit report to see if the mac addresses are in there? I'm not sure if the report would have that much detail but it might.
Yeah nothing useful there. Luckily I managed to find a week old inventory report I had done, so I found the elements I needed.
