07-27-2017 01:51 PM - edited 07-05-2021 07:26 AM
We had some issues and had to completely rebuild our
How can I get all our access points back with out manually adding all of them by
Is there a way Cisco Prime can auto discover and add them for me?
I know before when I would add an AP to the WLC it would automactially populate on Cisco Prime.
Thank
Solved! Go to Solution.
07-29-2017 02:23 PM
How can I get all our access points back with out manually adding all of them by ip?
Did you export maps from old system. If not you have to manually place the AP on floor maps.
You can add WLCs to prime and then Prime will know about your AP. Still AP will not be on floor maps, you have to assign them manually on the right locations of floor maps.
Rasika
*** Pls rate all useful responses ***
07-29-2017 02:23 PM
Rasika
