01-29-2014 11:06 AM - edited 07-05-2021 12:04 AM
We have configured Cisco Prime Infraestructure to get email notifications. Problem is that we are getting alerts for all controllers and APs
configured in Prime, and some of them are managed by another team, so I would like to know if it could be possible to configure some kind
of filter to get the alerts only for controllers we are interested?
Any ideas would be very much appreciated.
Jhony Pardo
01-29-2014 11:08 AM
You can go to Operate | Alarms and Events and then click on an alram and click Email Notification from there you can enable or disable some alarms and set the email.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-29-2014 11:11 AM
For reference:
Here is another thread regarding specific alarms only which may not be possible:
https://supportforums.cisco.com/thread/2264131?tstart=0
Scott
01-29-2014 11:23 AM
Your best bet is to create different virtual domains on PI, this way your different groups can see only their devices and can be alerted on their own devices.
Scott
07-14-2014 05:16 PM
Hi Scott
I have not a good understanding how virtual domain it can helps. How do you suggest using virtual domains?
In my case there are only three administrators in the network and they are not interested about getting email notifications from the ports connecting end users in access switches, but they are interested about uplink ports notifications and CPU, memory, environment from the same switches.
Hope your support.
Marcelo
