10-22-2013 09:28 AM - edited 07-04-2021 01:07 AM
Would anyone happen to know a good server build would be to run Cisco Prime Infrastructure for 5k in network devices. I can only find VM information and not physcial hardware specifications in regards to this.
Solved! Go to Solution.
10-22-2013 02:29 PM
You won't because CPI only comes in two flavours: VM and Cisco's "own" appliance.
You won't be able to build a CPI from a generic box anymore (not like WCS).
Cisco's appliance is from IBM.
10-23-2013 12:29 PM
Kindly check the following link (Data sheet for PI)
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/data_sheet_c78-729088.html
and you can check the server specification from cisco and follow cisco recommended as best practice
10-24-2013 04:43 AM
Cisco Prime Infrastructure runs on a 64-bit, Red Hat Linux Enterprise Server 5.4 operating system. You cannot install Cisco Prime Infrastructure on a standalone operating system such as Red Hat Linux, as Cisco Prime Infrastructure is shipped as a physical or virtual appliance that comes preinstalled with a secure and hardened version of Red Hat Linux as its operating system.
10-22-2013 02:29 PM
10-23-2013 12:29 PM
10-24-2013 04:43 AM
10-24-2013 06:30 AM
Thanks everyone that have posted. I was finally able to get a hold of our VAR and they specified the same information after discussing with Cisco.
