08-30-2017 01:09 PM - edited 07-05-2021 07:35 AM
Greetings:
We have 47 sites using a pair of 5520 SSO for FlexConnect. When I add my new RTU 3 Ap license for a small branch the message returned by the WLC said reboot required. Can I ignore this? It’s an operation nightmare to reboot, requires change management and service disruption notices. I thought I read somewhere reboot not required.
08-30-2017 08:27 PM
that´s correct. We can see this on Cisco doc. For RTU they dont ask to reboot, but
Before it was requested.
01-23-2019 09:23 PM
Hi Robert,
Just wondering how the AP adder turned out. I am in a similar situation. Cisco doc says just save config but after hitting the set count button..a message popped up that reboot is necessary. if you did reboot,since its in HA, am guessing you had to reboot both controller one time. Appreciate your feedback in advance.
AB
01-23-2019 09:27 PM
