clear dhcp bindings (leases) at WLC
holgerseiler
Hello all,
could anybody tell me how I could clear the dhcp bindings at a WLAN-Controller 7.0? I looked at 'configuration guide' and 'command reference', but I found nothing.
Thanks and regards
Holger
2 Accepted Solutions
Hi Holger,
Thanks for the response!!
if you are running 7.0 and above then its possible.. just now checked the same on my WLC.. the command is..
(WiSM-slot2-2) >config dhcp clear-lease ?
   Enter the IP address.
all            Clear all Leases.
let me know how this works out for you!!
Surendra
Surendra BG
did that resolve the issue?
Surendra
Surendra BG
8 Replies 8
Surendra BG
Where is the DHCP pool configured?? is der a local pool?? or is it on the server or layer 3 device??
Surendra
Surendra BG
Hello Surendra,
the pool or scope is configured at the WLC locally.
Holger
Hi Holger,
Surendra
Surendra BG
thank you very much. Issue is solved
Kind regards
Holger
Thanks for using the support Community!!
Have a great day!!
Surendra
Surendra BG
Surendra
Surendra BG
JOSE RIVERA
Thanks Surenda,
That did the job.
Jose
stevep1969
Thanks. Worked perfect
Steve
