11-30-2016 05:48 AM - edited 07-05-2021 06:11 AM
Just wondering if there's any way to adjust the columns in the web user interface on 8.0.133.0. Specifically, the Wireless tab has useless column widths that are IMO way too wide. I want to see how many users are on each AP, and this is a struggle on a regular monitor.
Thanks!
Solved! Go to Solution.
11-30-2016 11:03 AM
I do not think you can modify it.
You can use "show ap summary" CLI output to get it filtered nicely.
(WLC01) >show ap summary
Number of APs.................................... 189
AP Name Slots AP Model Ethernet MAC Location Country IP Address Clients
L1RXXXR00-AP01 2 AIR-LAP1131AG-N-K9 00:1d:e5:56:e8:ee default location AU 10.8.0.129 0
L2RXXXR00-AP01 2 AIR-LAP1131AG-N-K9 00:1d:e5:56:ea:d2 default location AU 10.8.0.131 1
L1R0000R00-AP01 2 AIR-LAP1242G-A-K9 88:43:e1:03:ba:f8 inside main corr AU 10.15.6.62 0
Rasika
*** Pls rate all useful responses ***
11-30-2016 11:03 AM
Rasika
11-30-2016 11:14 AM
I was guessing there was no way to fix it. Thanks for the CLI command, that might work. :-)
....IMHO this is another example of my old project management directive: Never let the engineers create the UI. lol
