Config network broadcast
Felipe Agudo
I know that I can enable Broadcast in the WLC using CLI( config network broadcast enable ). Can I do it in the Web Interface?
Regards.
HI,
Ok now I got ur point.
Here is the GUI Procedure to do it .
Controller > General > enable the Broadcasting forwarding
Here is the screenshot:
DONt forget to rate helpful posts
Sandeep Choudhary
yes you can do it .
Login to WLC GUI.
WLAN > Click on WLAN ID > General > then check the box for broadcast.
Dont forget to rate helpful posts
I think that you don't understand my question.
The answer you give me corresponds to the following command:
config wlan broadcast-ssid enable
The command that I'm referring to is :
HI,
Correct Answer
Thank you!
