07-14-2019 07:59 AM - edited 07-05-2021 10:42 AM
HI all,
I have to configure the WLC 5520 (IOS 8.5.x) as Radius Server for wifi client.
all the guides read refer to an external radius but I want to use the same wlc as radius, is it possible?
can someone tell me the process?
Thanks a lot.
regards
07-14-2019 08:25 AM
- That is not possible.
M.
07-14-2019 03:05 PM
If it is a small scale deployment, you can use Local EAP configuration on WLC to act is as local radius server. Refer below document "Local EAP" section.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/wlan_security.html
But that does not mean WLC can act as full fledge RADIUS server (like Free RADIUS, Microsoft NPS, Cisco ISE, Aruba ClearPass)
Rasika
*** Pls rate all useful responses ***
