04-20-2018 11:22 AM - edited 07-05-2021 08:32 AM
Is there a way to copy WLAN's from an 8510 to a 5508? I have prime and I discovered templates from the 8510 but can't seem to choose the 5508 under the deploy option. Also, is there a way to do a bulk deployment of all of the WLAN's as I have almost 100.
04-23-2018 01:45 AM
04-23-2018 05:25 PM
My customer has chosen to have the 5508's as their disaster recovery units. They have two of them to take over for the 8510 should a disaster happen. Between us, I doubt they will ever get used.
The EoL issue could very well present itself in a few ways, especially if they ever decide to upgrade their code on the 8510 past what the 5508 can handle.
Not my suggestion, but what the customer wants.
Thanks.
04-25-2018 08:31 AM
Just be aware that 5508 can only handle 500 AP's. 8510 manages, with no issues based on my own experience, from 1000-1300 AP's.
I do not like 8510 at all because it does not have CIMC option so if you face the same issue I had in the past regarding the built-in license, the only option available is an RMA. One of the benefits of CIMC is that you can reinstall that license. I have not check in detail the 5520 yet.
04-23-2018 02:26 AM
If cisco PI doesnt allow to deploy it then open both WLC GUI parallael and try to configure the wlan from scratch on new WLC . It will take time but less chances of errors or misconfiguration.
Dont forget to rate helpful posts
04-23-2018 05:36 PM
I used Prime to get a text of the configuration and then I am modifying the text to be able to dump it into the 5508's.
Thanks for the help.
04-24-2018 10:20 PM
yes you can do if it has the same software version.
04-25-2018 05:22 AM
04-25-2018 05:28 AM
First...: you better also to read release notes for your version in case it includes any special instructions about backup/restore operation.
If Backup/Restor not working then..I will use the one to one method(open both WLCs GUI parallel ) to confgure new WLC (From scracth), honestly it only takes a little while to build out the new config.
