554
Beginner
Data Migration from WCS to NCS
I am working on a migration from Windows based WCS 7.0.164.3 to NCS appliance (1.2.1-once it is available).  After stopping WCS, I issued the export userdata C:\WCS07Migrate.  The process completed, but did not create a single zip file. I found 2 files created in the tmp directory.   One contains multiple  a folder called
tempDirUserDataFromDb - containing multiple xml files; and another file called ImportExport_ca<number> which contains the maps.  Was there something incorrect in my command?  Can I use still use these files on NCS? Or do I need to redo the export on the WCS?  Thanks
.rob
Everyone's tags (4)
3 REPLIES 3
Beginner
Read Rollin's post from earlier.  Need to upgrade to 7.0.220.
yes, 7.0.230.0 would be even better.
WCS can't be migrated directly to PI 1.2.1. It would be a two step process:
1. WCS 7.0.230.0 to NCS - 1.1.1.24
2. NCS - 1.1.1.24 to PI - 1.2.1.12
Ram
Beginner
From what I understand you cannot do a WCS import into NCS 1.2 as the NCS MIGRATE command is not available. You need to use NCS 1.0 or 1.1 to do the migration from WCS, then update to NCS 1.2. We ran into this problem and decided to start over from scratch instead of worrying about the Migration, I didn't want to blow away our 1.2 install.
Content for Community-Ad
August's Community Spotlight Awards
