Detecting Rogue Clients
david.enenkel
Hy,
we are playing around with the Rogue AP Detection at the moment. For this we have setup a test scenario where we have a Rogue AP connected to our network using WPA2 PSK and several clients connected to it.
What can cause that a AP sees the Rogue AP (mac) but not the rogue clients mac connected to it ?
all the very best
David
Hi David,
These are the Rogue debugs that we have on the WLC..
(WiSM-slot2-1) >
(WiSM-slot2-1) >
(WiSM-slot2-1) >debug dot11 rogue ?
disable        Disables debug.
enable         Enables debug.
rule           Configures debug of 802.11 rogue rule events.
Surendra
Surendra BG
10 Replies 10
Surendra BG
Hi David,
If the AP is in Monitor Mode, then you Should or You must see the Rogue clients as well.. if not then there is a problem with the code or the client driver..
do we hav the AP in monitor mode??
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Hello Surendra,
thanks for your reponds. No the APs are in local mode. As i have read in the documentation in local mode the APs monitor for noise and rogue ap's for 50 ms.
Nevertheless i have an update on our situation . Just fife  minutes ago (now after having the client over 24 hours connected) it has recognised it.
Does this mean that the 50 ms are to short to recognise all of the rogue details?
all the very best
David
oops.. sorry the previous post was for something else!! but both the users name was David!! and coming back.. i am not sure about the time Gap or the metric... i normally go for Monitor Mode and then wait for the SNMP log on the WCS..
Surendra
Surendra BG
Leo Laohoo
The WLC/WCS can see rogue clients associated to a rogue AP even in local mode.  By default, auto-contain of rogue AP is disabled.  Be careful of legal repercussions to enable auto-contain of rogue AP or manual contain of rogue AP and clients.
The feature does not look very consistend to me. The rogue client has only be seen for a few minutes on our WLC and then again vanished. Since then , though it is active all the time it has not been recognised by any AP in this area. Any additional thoughts on this ?
all the very best
David
Hi David,
Hope you are doing great!!
If you are able to see the inconsistencies on the rogue, then i request you open up a TAC case and we will open up a Software bug and help you out in getting the issue resolved.
Surendra
Surendra BG
Hello  Surendra
is there a possibility to debug the rogue detection on the local AP itself ?
all the best
David
Hi David,
(WiSM-slot2-1) >
(WiSM-slot2-1) >
Surendra
Surendra BG
I have now added an additional AP in "Monitor Mode" . Since then the Rogue Clients are discovered in a consistend manner. Nevertheless adding additional "monitor AP's" all over the place is not really a prefered solution from us and i'm a little bit disappointed that the "local Mode" scanning does not work that good.
all the very best
David
Hi David,
The Monitor mode is specifically for this purpose as per my very first post in this thread... so we do get the data correctly..
Surendra
Surendra BG
