01-20-2014 05:41 AM - edited 07-05-2021 12:00 AM
Hi Team,
What is the difference between india and GB regulatory domains with channels and usage.
LAP-1131AG-E-k9
LAP-1131AG-N-k9
number of channels?
number of non overlapping channels?
Arun
Solved! Go to Solution.
01-21-2014 04:17 AM
Here is a good reference for your 1131 and channel and power matrix
http://www.cisco.com/en/US/docs/wireless/access_point/channels/lwapp/reference/guide/1130_chp.html
01-20-2014 06:12 AM
01-21-2014 01:59 AM
Hi Sandeep and scott,
Thanks for the reply
is there any production impact or limitation will be getting when i use ETSI(-E-) regulatory in
India ( - N -) as a mixed type?
GB ap's are working with N type Ap together in india?
Arun
01-21-2014 02:14 AM
HI Arun,
Yes or No.......
If your WLC has multiple Regulatory Domain configured, only common channels will be enabled
When you configure your WLC to have both APs in the Regulatory Domain, it means that the WLC has to turn OFF channels which are not allowed in both countries. This only leaves common channels left enable.
Configuring a country code ensures that each radio's broadcast frequency bands, interfaces, channels, and transmit power levels are compliant with country-specific regulations.
They will work with comman channels.
Dont forget to arte helpful posts
01-20-2014 06:39 AM
Just to add...
If you intend to have multiple country codes enabled on the WLC, the WLC will only use the common power and channels allowed from the regulatory domains that were enabled on the WLC.
http://nostringsattachedshow.com/2012/02/02/multiple-country-codes-with-the-cisco-wlc/
01-21-2014 02:17 AM
Thanks scott.
So if i use the -E and -N together in same location what will happen?
LAP-1131AG-E-k9
LAP-1131AG-N-k9
Arun
01-21-2014 02:30 AM
HI Arun,
If you have country code :GB on your WLC then this AP(LAP-1131AG-N-k9) will not join to WLC.
It will shows as regulatry domain mismatch or it will not join.
If you want to join both AP to this countroller then u need to configure multiple country code on WLC(Normally its not recommanded):
iTS RECOMAMNDED TO HAVE.
i would have a dedicated WLC for each region like eUROPE, Asia . Now depending on the individual countries regulation for channel and power, I would possible have a WLC for each country due to the fact that like i mentioned in my last post, the WLC will use the most common channels and power levels.
Dont forget to rate helpful posts
01-21-2014 02:52 AM
Hi Sandeep,
Thanks!
is there any exact table to find frequency bands, interfaces, channels, and transmit power levels are compliant with country-specific regulations?
Because we are going to deploy the Ap's our network before want to know the exact difference in hardware and functions.
Arun
01-21-2014 03:07 AM
HI Arun,
Here are the specification 1131 AP: Please check this document:
Thats all document I have for you.
Hope it helps
01-21-2014 02:57 PM
If you will or don't have any WLC, then you can use the APs even though they have incorrect regulatory domain.
01-21-2014 09:20 PM
Hi Leo,
So it wont create any issue when it work as mixed regulatory domain in same locations.right?
01-21-2014 11:08 PM
HI Arun,
Yes they may work.....may be not
But if they are work then work according to countries regulation for channel and power,This only leaves common channels left enable.
01-22-2014 12:57 AM
Autonomous IOS don't care what regulatory domain you are using.
01-21-2014 04:17 AM
