EAP-LEAP Module for Windows Vista & 7?
nowiressecurity
I’m trying to understand the 802.1X clients/modules Cisco offers. I found the Cisco Secure Services Client and the EAP-FAST Module for Win Vista/7. But where do I download or learn more about the EAP-LEAP Module for Win Vista/7?
5 Replies 5
Nicolas Darchis
Why would anyone desire to do LEAP on Windows 7 ?
LEAP is known to be unsecure and if you have the chance to do eap-fast, you shouldn't be doing LEAP
Yes, I agree. Just researching for an article I'm doing on third-party supplicants. It was hard to find info on the EAP-FAST module, but I can't find the EAP-LEAP module anywhere.
Well you can try this:
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-do-i-install-cisco-eap-fast-on-my-computer.aspx
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-can-i-download-the-ecp-methods-from-the-web.aspx
however I dont know if it is needed, but on my computer I already have LEAP EAPFAST and cisco PEAP
From intel, EAP-SIM, EAP-TTLS and EAP-AKA
Im running Windows 7 ultimate
I can see these options on WZC when I am setting up the security options on the profile.
I recently downloaded the wireless drivers for my Intel 3945ABG wireless card. So I cant really explain if there were since the begining or thru a windows update or maybe due to the manually updated Intel drivers...
Hope it helps you
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-do-i-install-cisco-eap-fast-on-my-computer.aspx This shows just how to install EAP-FAST, which works for me.
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-can-i-download-the-ecp-methods-from-the-web.aspx I can find "ECPNode" via the Windows Update site but only installs EAP-FAST
Yeah, I've read that some people find EAP-LEAP and/or EAP-FAST installed automatically by I think Windows Update.
Does the wireless adapter have to specifically support these EAP protocols? maybe that's the problem.
Ravi Singh
Level 7
Level 7
Please check the below link
http://www.cisco.com/c/en/us/td/docs/wireless/wlan_adapter/cb21ag/user/vista/1-0/configuration/guide/cb21ag10vistaconfigguide/eap_types.html
