07-24-2019 04:28 AM - edited 07-05-2021 10:44 AM
Hi Team,
my setup consist of below infra
We have fortigate firewall for gateway & internet access.
five access point & one WLC for them to Manage.(AIR-CT2504-K9)
These five access point are having three different WLAN (different SSIDs)
20 Laptop users which access internet through wifi.
DHCP server configured on fortigate firewall. all clients are getting IP address directly from fortigate firewall.
Requirement
We want to setup dhcp server on cisco WLC (AIR-CT2504-K9) for only one SSID so that when user connect to that SSID they will get particular IP Address range & I can restrict those user internet access.
rest of the SSIDs will keep on continue to release IP from fortigate firewall.
Please let me know how can I achieve these without conflicting rest of the setup.
Solved! Go to Solution.
07-24-2019 05:25 AM
Here is the post about internal DHCP scope on WLC:
http://netterrene.blogspot.com/2014/08/internal-dhcp-scope-in-cisco-wlc-via-gui.html
Dont forget to rate helpful posts
07-24-2019 05:02 AM
Yes its possible.
1. Create DHCP scope of specific network Which you are using for specific WLAN.
2. Assign DHCP server "WLC Mgmt INterface IP" under the dynamic interface of that wlan for whcih you are having a local dhcp scope on WLC.
07-24-2019 05:07 AM
07-24-2019 05:25 AM
07-24-2019 05:13 AM
07-24-2019 05:26 AM
07-24-2019 05:42 AM
There are many docs available online about how to configure internal DHCP on WLC:
07-25-2019 03:43 AM
