05-16-2011 01:08 PM - edited 07-03-2021 08:12 PM
If I setup an 1131 Cisco access point with WPA2 does that encrypt just the authentication portion for access, or does each packet going forward, once successfully authenticated, get encrypted also?
William
05-16-2011 02:40 PM
What I basically want to know is after I have successfully authenticated using a WPA2 password to the access point can someone still sniff my connection and capture my future traffic?
05-16-2011 05:36 PM
WPA2 will do that Authentication and the AES will encryp the data you send..
lemme know if this naswered ur question!!
Surendra
05-17-2011 05:15 AM
So to summarize you are saying that setting up WPA2 authentication then creates an encrypted session till I disconnect? Basically making my connection be secured from the ability to sniff my packets while I browse or work on files after successfully suthenticating? I don't need to connect and then establish a VPN to secure y connection?
Just clarifying
05-17-2011 05:21 AM
Yes you are right!! the data will get encrypted by 128bit AES.. not sure about the exact terminology.. please google it and you will be able to find the same in IEEE papers or WPA2 scrub notes..
Lemme know if this naswered ur question and please dont forget to rate the usefull posts!!
Surendra
05-17-2011 05:26 AM
Do you have a good Cisco link that describes how the entire session is encrypted, and not just the authentication portion?
05-17-2011 05:33 AM
Here is the link..
http://en.wikipedia.org/wiki/Wi-Fi_Protected_Access#WPA2
http://en.wikipedia.org/wiki/Advanced_Encryption_Standard
Surendra
