09-15-2019 01:10 PM - edited 07-05-2021 11:00 AM
Dear,
I have a CORE switch, which is a root bridge of all VLANs in my environment. I want to use flex-link on a particular port. When I set the flex-link feature on my CORE switch interface, will this cause Spanning-tree to be disabled only from the interface I'm setting flex-link to, or will it disable STP from all interfaces on my CORE switch?
thankful
Rafael
Solved! Go to Solution.
09-15-2019 03:06 PM
It can co-exist with the same environment as STP, make sure you ready config guidelines, yes you can configure certain network.
example reference guide :
09-15-2019 03:06 PM
09-15-2019 03:11 PM
Doubt answered. Thank you!
