117
Beginner
Flex-Link Influence on Switch STP Configuration
Dear,
I have a CORE switch, which is a root bridge of all VLANs in my environment. I want to use flex-link on a particular port. When I set the flex-link feature on my CORE switch interface, will this cause Spanning-tree to be disabled only from the interface I'm setting flex-link to, or will it disable STP from all interfaces on my CORE switch?
thankful
Rafael
1 ACCEPTED SOLUTION
VIP Advisor
Re: Flex-Link Influence on Switch STP Configuration
It can co-exist with the same environment as STP, make sure you ready config guidelines, yes you can configure certain network.
example reference guide :
https://community.cisco.com/t5/networking-documents/how-to-configure-a-flex-link-for-link-level-redundancy-in-cat/ta-p/3133234
BB
*** Rate All Helpful Responses ***
2 REPLIES 2
VIP Advisor
BB
Beginner
 Doubt answered. Thank you!
Content for Community-Ad
August's Community Spotlight Awards
