09-27-2018 06:12 AM - edited 07-05-2021 09:14 AM
We have a guest SSID configured using MAB authentication with ISE (I am completely new to this as our network engineer has left, so this is about as much as I know!).
I've been asked to find out if we can restrict this SSID to allow it to only go to one specific website, is this possible and if so how can I do this?
Many thanks.
09-27-2018 06:27 AM - edited 09-27-2018 06:28 AM
you could apply an ACL to allow the ip address of the website and then deny everything else.
Dont forget to arte helpful posts
09-27-2018 06:44 AM
09-27-2018 06:49 AM
Are you using ISE for MAB authentication or ?
yes that will be filtered with IP address rahter then domain name!!
Dont forget to rate helpful posts
09-27-2018 06:58 AM
09-27-2018 07:03 AM
you can create ACL in WLC or DACLin ISE and push it from ISE via AuthZ profiles.
09-27-2018 07:05 AM
