06-09-2015 08:44 AM - edited 07-05-2021 03:22 AM
Hello follow networkers,
I need to create a guest network and ensure that users go STRAIGHT to the Internet without connected to my other wireless network. I will also want to create new SSID for this Guest wireless network.
I am using 5508 Wireless Lan Controllers for this implementations.
FE
Solved! Go to Solution.
06-09-2015 09:49 AM
That should not be a problem. Create a new interface on the controller for guests, connect that to your guest network, create a new SSID on the controller and associate it to the new interface you created.
See this
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70ovrv.html
Leonard
06-10-2015 05:33 AM
The Guest Access solution is self-contained and does not require any external platforms to perform access control, web portal, or AAA services. All these functions are configured and run within the anchor controller. However, the option exists to implement one or all of these functions externally and is discussed later in the chapter.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob73dg/emob73/ch10GuAc.html
06-09-2015 09:49 AM
See this
Leonard
06-10-2015 03:15 AM
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/70937-guest-internal-wlan.html
06-10-2015 05:33 AM
