guest wlan
goncalo.girao
Almost there.
Scenario:
2504 wlc
Aps 1140
Port 1 lan radius all ok
Port 2 defined for guest wlan directed attach no isp router dhcp
1 utp cable on router acquire ip address
On guest wlan no ip address is given i think i tried every combinations
Any help?
You need to do NAT no matter what... the WLC doesn't do NAT.  What I would do is:
  • Create an interface for your internal ssid
  • Create an interface for your guest ssid
  • Make port 1 primary for both interfaces
  • On the Internal interface, configure the primary dhcp to your internal dhcp
  • On the guest interface, configure the management ip of the WLC as the DHCP
  • Configure a DHCP scope on the WLC for the guest and make sure you use the ISP as the gateway
  • On your Internal SSID, map the internal interface
  • On the guest SSID, map the guest interface
That should do it... this way you use your internal dhcp for your internal users and the WLC for your guest.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
17 Replies 17
Scott Fella
This is how you need to setup your wlc. Port 1 is your internal so in the management interface and any dynamic interfaces for your internal you need to specify port 1 as primary and port 0 as backup. On the guest dynamic interface you need to specify port 2 as primary and port 0 as backup. Now your placing the traffic on the correct interfaces.
If your router in the guest side is the dhcp server, you need to either disable dhcp proxy in the wlc. Dhcp proxy is required if your using the wlc as a dhcp for any vlans you have defined on the wlc. From the wlc cli or GUI try to ping the guest gateway address.
Also always test with an open said to start with and also you can test using a wired device connected to the guest subnet to verify dhcp and Internet connectivity.
-Scott
goncalo.girao
That's my doubt. On port 1, is connected to my switching and consecutively to the main dhcp server. Can i have a different one on the second port? I see in debug that port 2 tries to reach the correct dhcp ( a new one assigned by my isp)
Ps yes all that you desvribed is configured, except the dhcp proxy option. I will disable it later when office
So the way I explained is really the only way unless you just use port 1 and trunk that to your switch. Then connect your guest network into a clan in the switch and let your layer 3 do the routing. The wlc will not route and only bridge.
You might be better off using the wlc as the dhcp for the guest and stay with the design I mentioned earlier. Your guest router will need to nat though.
-Scott
goncalo.girao
I dont have layer 3 on switching capabilities
So i have to route (we are doing routing no nat) on isp
I tried that option early (enable dhcp on wlc) bur for some unknown reason the wlan couldn't obtain a valid ip also
Will try tomorrow ty
So, what are the steps to make DHCP work (only on this Guest WLan)?
Any helps? TY
Well how do you have it setup?
-Scott
Well, right no i only have dhcp but isnt enabled. And the guest lan is also disabled and not broascasting ssid.
How is the controller setup. You using LAG or not? How many ports on the wlc is connected to the switch? What is the ip of your dhcp server?
Post the show WLAN for each of your WLAN's you have created.
-Scott
Scott Fella wrote:
How is the controller setup. You using LAG or not? (NO, it supports???) How many ports on the wlc is connected to the switch? (ONE)  What is the ip of your dhcp server? (My lan dhcp - 192.168.2.a)
WLAN Identifier.................................. 3
Profile Name..................................... Guest WLan
Network Name (SSID).............................. WYguest
Status........................................... Disabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
--More-- or (q)uit
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Disabled
--More-- or (q)uit
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
--More-- or (q)uit
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
Scott Fella
So you only have one ssid shown. If your placing your guest on the management interface, just make sure you add the dhcp on the management interface.
-Scott
But can I Have the 2 dhcp on different ports and/or interfaces? I dont want my LAN dhcp to gave ip addresses do Guest.
WLAN Identifier.................................. 4
Profile Name..................................... XXX
Network Name (SSID).............................. XXX
Status........................................... Enabled
Broadcast SSID................................... Enabled
Number of Active Clients......................... 2
--More-- or (q)uit
CCX - AironetIe Support.......................... Enabled
Peer-to-Peer Blocking Action..................... Drop
Radius Servers
--More-- or (q)uit
Security
         TKIP Cipher............................. Enabled
                                                               Auth Key Management
--More-- or (q)uit
I Think the idea is doing NAT, shouldnt?
Scott
-Scott
  • On the guest interface, configure the management ip of the WLC as the DHCP - Cant do it -
"IP Information conflicts with another interface".
Scott
