Hi everyone,
A client need a integration between WLC and NPS (IAS server),searching in cisco i can't find a document that help me to install this solucion, also i need requeriment for this implementation, i mean what version of SO NPS is compatible with what SO of WLC.
Thanx for the answer
Solved! Go to Solution.
Check this out.
Starting on page 134. Takes you through installing CA, building template for NPS, installing NPS, connection request policy, network policy, etc.
Also, in terms of user and machine auto-enrollment for certificates, refer to Microsoft Technet. These should get you started.
2008 R2 NPS Setup
1. Install Cert Authority, Web Authority (default install)
http://technet.microsoft.com/en-us/library/cc501466.aspx
2. Deply a CA and NPS Server Certiricate
http://technet.microsoft.com/en-us/library/cc730811.aspx
3. Install NPS (Network Policy Server only)
http://technet.microsoft.com/en-us/library/cc732912.aspx
4. Register NPS Server in AD DS.
http://technet.microsoft.com/en-us/library/cc754878.aspx
5. Deploy Client Computer Certificates
http://technet.microsoft.com/en-us/library/cc731242.aspx
6. Deploy User Certificates
http://technet.microsoft.com/en-us/library/cc770857.aspx
7. Certificate Requirements for PEAP and EAP
if you are running 2k8, any NPS you have will work.
If you are looking for a guide for NPS, the technet article from Microsoft is your best bet. On the WLC side you simply define it under the RADIUS server, via the IP, ports and shared secret.
Steve
Thank you steve for the quickly answer and for clearing. Well my client ask me a cisco document where say that this implementation is posible so sorry abuse but do you have this kind of document??
Thank
there is no such document. so long as the AAA server follows the IEEE guides, it will work.
Steve
Ok thank you again, so you say that do not exist a requirement of SO of the NSP for implementation with WLC i mean a windows 2008 R2 enterprices it's the same tha't a windows 2008 R1 ?
For where the WLC is concerned, there is no difference.
Steve
Check this out.
2008 R2 NPS Setup
Man thank a lot with the document and the explanation. You save my as... jajajajaj
