how can i force client to choose Which AP to connect
xiongzhiwei
hello all
Currently we have a issue that when our wifi is running ,some of aps have too much clients such as
AP1:100clients
AP2: 20clients
AP3: 15clients
how can I do to put a great of clients from ap1 to ap2 or ap3 ? I had already tried to reduced the ap1's power level and increase for others and disabled the low data rates , but It looks like doesn't work.
Thanks for everyone's help !
My wlc is 2504 and my ap is 3702
16 Replies 16
Leo Laohoo
You can't.  The wireless clients are the one that chooses which APs to join.
Upgrade the drivers to the wireless clients helps a lot.
thank you for your reply
Do you have any idea to resolve the issue that some of aps have too much clients but others are not ?
What are these wireless clients?  Are they laptops/netbooks?  Are they smartphones/tablets?
Actually half of they are laptops and others are smartphones , you know people often have two or more decives now .
For now, upgrade the drivers of the wireless NIC and see if it improves things.
Are you able to determine if this issue is affecting 802.11b MORE than 802.11a?
Hi Leo
thank you for you answer !
correct ! this issue is affecting 802.11b MORE than 802.11a . so you think now the only way I can try is upgrade the dirvers of the NIC ?
If the users connect to 802.11g more then 802.11a, you should check your load balance setting, WLC -- Wireless -- Advanced -- Load Balance.
Hmmmm ... Co-channel interference.  What exact models of APs?
Unless you're looking for more trouble, DO NOT enable Load Balancing.
Hmmm.. what's the meaning of ap's exact models ? do you mean if ap working at 802.11a and 802.11b ?
No, what are the different AP models do you have?
ap model is AIR-CAP3702I-H-K9
Ok, so is CleanAir enabled?
Pick two APs that the wireless clients don't "like" to go to and post the complete output to the command "sh ap auto-rf 802.11b <AP Name>".
yes Cleanair is enabled
here is the output :
(Cisco Controller) >show ap auto-rf 802.11b YXP-AP-3F-08
Number Of Slots.................................. 2
AP Name.......................................... YXP-AP-3F-08
MAC Address...................................... ec:bd:1d:80:13:8c
  Slot ID........................................ 0
  Radio Type..................................... RADIO_TYPE_80211b/g
  Sub-band Type.................................. All
  Noise Information
    Noise Profile................................ PASSED
    Channel 1....................................  -91 dBm
    Channel 2....................................  -86 dBm
    Channel 3....................................  -86 dBm
    Channel 4....................................  -79 dBm
    Channel 5....................................  -69 dBm
    Channel 6....................................  -87 dBm
    Channel 7....................................  -83 dBm
    Channel 8....................................  -61 dBm
    Channel 9....................................  -84 dBm
    Channel 10...................................  -88 dBm
    Channel 11...................................  -83 dBm
    Channel 12...................................  -86 dBm
    Channel 13...................................  -87 dBm
--More-- or (q)uit
  Interference Information
    Interference Profile......................... PASSED
    Channel 1....................................  -55 dBm @ 12 % busy
    Channel 2....................................  -46 dBm @  2 % busy
    Channel 3.................................... -128 dBm @  0 % busy
    Channel 4.................................... -128 dBm @  0 % busy
    Channel 5.................................... -128 dBm @  0 % busy
    Channel 6.................................... -128 dBm @  0 % busy
    Channel 7.................................... -128 dBm @  0 % busy
    Channel 8.................................... -128 dBm @  0 % busy
    Channel 9.................................... -128 dBm @  0 % busy
    Channel 10...................................  -59 dBm @  6 % busy
    Channel 11................................... -128 dBm @  0 % busy
    Channel 12...................................  -58 dBm @  2 % busy
    Channel 13................................... -128 dBm @  0 % busy
  Load Information
    Load Profile................................. FAILED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 2 %
    Channel Utilization.......................... 81 %
    Attached Clients............................. 28 clients
  Coverage Information
    Coverage Profile............................. PASSED
--More-- or (q)uit
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 0 clients
    RSSI  -68 dbm................................ 2 clients
    RSSI  -60 dbm................................ 5 clients
    RSSI  -52 dbm................................ 21 clients
  Client Signal To Noise Ratios
    SNR    0 dB.................................. 0 clients
    SNR    5 dB.................................. 0 clients
    SNR   10 dB.................................. 0 clients
    SNR   15 dB.................................. 0 clients
    SNR   20 dB.................................. 3 clients
    SNR   25 dB.................................. 0 clients
    SNR   30 dB.................................. 2 clients
    SNR   35 dB.................................. 6 clients
    SNR   40 dB.................................. 9 clients
    SNR   45 dB.................................. 8 clients
  Nearby APs
    AP 00:c8:8b:3a:29:90 slot 0..................  -81 dBm on   1 (0a:46:37:fd:00:4b)
    AP 00:c8:8b:3a:2a:00 slot 0..................  -76 dBm on  11 (0a:46:37:fd:00:4b)
--More-- or (q)uit
    AP 00:c8:8b:3e:f3:a0 slot 0..................  -61 dBm on   1 (0a:46:37:fd:00:4b)
    AP 00:c8:8b:5c:d7:90 slot 0..................  -50 dBm on   1 (0a:46:37:fd:00:4b)
    AP 00:c8:8b:5c:dc:20 slot 0..................  -82 dBm on   1 (0a:46:37:fd:00:4b)
    AP 00:f2:8b:96:f3:10 slot 0..................  -78 dBm on  11 (0a:46:37:fd:00:4b)
    AP 00:fe:c8:2f:63:e0 slot 0..................  -64 dBm on   6 (0a:46:37:fd:00:4b)
    AP 00:fe:c8:33:1e:90 slot 0..................  -46 dBm on   6 (0a:46:37:fd:00:4b)
    AP 00:fe:c8:eb:b7:d0 slot 0..................  -47 dBm on  11 (0a:46:37:fd:00:4b)
    AP 04:62:73:61:e7:40 slot 0..................  -86 dBm on   1 (0a:46:37:fd:00:4b)
    AP 58:97:bd:6e:d3:10 slot 0..................  -48 dBm on   6 (0a:46:37:fd:00:4b)
    AP 5c:83:8f:78:f6:60 slot 0..................  -84 dBm on   6 (0a:46:37:fd:00:4b)
    AP 5c:83:8f:b8:14:90 slot 0..................  -84 dBm on   1 (0a:46:37:fd:00:4b)
    AP 5c:83:8f:fe:ff:f0 slot 0..................  -64 dBm on  11 (0a:46:37:fd:00:4b)
    AP a8:9d:21:ee:03:f0 slot 0..................  -58 dBm on   6 (0a:46:37:fd:00:4b)
    AP e4:aa:5d:07:de:e0 slot 0..................  -72 dBm on   1 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:10:32:00 slot 0..................  -83 dBm on  11 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:1d:04:c0 slot 0..................  -63 dBm on   1 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:62:13:40 slot 0..................  -67 dBm on   6 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:62:1f:30 slot 0..................  -62 dBm on  11 (0a:46:37:fd:00:4b)
  Radar Information
  RF Parameter Recommendations
    Power Level.................................. 5
    RTS/CTS Threshold............................ 2347
    Fragmentation Threshold...................... 2346
--More-- or (q)uit
    Antenna Pattern.............................. 0
  Persistent Interference Devices
  Class Type                 Channel  DC (%%)  RSSI (dBm)  Last Update Time
  All third party trademarks are the property of their respective owners.
(Cisco Controller) >show ap auto-rf 802.11b YXP-AP-3F-02
AP Name.......................................... YXP-AP-3F-02
MAC Address...................................... ec:bd:1d:5d:7f:00
  Noise Information
    Channel 1....................................  -85 dBm
    Channel 2....................................  -83 dBm
    Channel 3....................................  -70 dBm
    Channel 4....................................  -68 dBm
    Channel 5....................................  -89 dBm
    Channel 6....................................  -85 dBm
    Channel 7....................................  -80 dBm
    Channel 8....................................  -89 dBm
    Channel 9....................................  -67 dBm
    Channel 10...................................  -77 dBm
    Channel 11...................................  -91 dBm
    Channel 12...................................  -90 dBm
    Channel 13...................................  -90 dBm
--More-- or (q)uit
    Channel 1....................................  -62 dBm @  8 % busy
    Channel 2....................................  -62 dBm @  2 % busy
    Channel 3....................................  -33 dBm @  2 % busy
    Channel 7....................................  -51 dBm @  2 % busy
    Channel 8....................................  -39 dBm @  1 % busy
    Channel 10................................... -128 dBm @  0 % busy
    Channel 11...................................  -54 dBm @ 10 % busy
    Channel 12...................................  -48 dBm @  2 % busy
  Load Information
    Transmit Utilization......................... 3 %
    Channel Utilization.......................... 78 %
    Attached Clients............................. 18 clients
--More-- or (q)uit
    RSSI  -68 dbm................................ 1 clients
    RSSI  -60 dbm................................ 2 clients
    RSSI  -52 dbm................................ 15 clients
    SNR   20 dB.................................. 1 clients
    SNR   30 dB.................................. 4 clients
    SNR   35 dB.................................. 5 clients
    SNR   40 dB.................................. 6 clients
    SNR   45 dB.................................. 2 clients
  Nearby APs
    AP 00:c8:8b:4b:01:60 slot 0..................  -66 dBm on   1 (0a:46:37:fd:00:4b)
    AP 00:c8:8b:5c:d7:90 slot 0..................  -61 dBm on   1 (0a:46:37:fd:00:4b)
--More-- or (q)uit
    AP 00:f2:8b:96:f3:10 slot 0..................  -54 dBm on  11 (0a:46:37:fd:00:4b)
    AP 00:fe:c8:2f:63:e0 slot 0..................  -73 dBm on   6 (0a:46:37:fd:00:4b)
    AP 00:fe:c8:33:1e:90 slot 0..................  -63 dBm on   6 (0a:46:37:fd:00:4b)
    AP 00:fe:c8:eb:b7:d0 slot 0..................  -63 dBm on  11 (0a:46:37:fd:00:4b)
    AP 04:62:73:61:e7:40 slot 0..................  -66 dBm on   1 (0a:46:37:fd:00:4b)
    AP 58:97:bd:6e:d3:10 slot 0..................  -66 dBm on   6 (0a:46:37:fd:00:4b)
    AP 5c:83:8f:fe:ff:f0 slot 0..................  -41 dBm on  11 (0a:46:37:fd:00:4b)
    AP a8:9d:21:ee:03:f0 slot 0..................  -42 dBm on   6 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:1d:04:c0 slot 0..................  -87 dBm on   1 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:62:1f:30 slot 0..................  -78 dBm on  11 (0a:46:37:fd:00:4b)
    AP ec:bd:1d:af:dd:80 slot 0..................  -62 dBm on   6 (0a:46:37:fd:00:4b)
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy...............  -39 dBm
    Previous Channel Average Energy..............  -13 dBm
    Channel Change Count......................... 8
    Last Channel Change Time..................... Sun Jul 17 16:12:46 2016
    Recommended Best Channel..................... 6
    Power Level.................................. 6
--More-- or (q)uit
  WiMax Mobile               11       0       -79         Fri Jul 15 10:47:45 2016
  WiMax Fixed                1        0       -68         Fri Jul 15 23:08:45 2016
                             6        0       -60         Mon Jul 18 19:54:39 2016
                             11       0       -59         Thu Jul 14 03:00:29 2016
81%???   That is really high.  Above 75% and the band is totally useless.
There are currently 28 wireless clients associated to this AP.
Judging from the output above, I am suspecting the wireless clients are behaving as expected.  They are avoiding APs with very high co-channel interference.
