Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
441
Highlighted
Beginner
How can we put our wireless networks on a schedule
We have two 5508s in a boarding school environment and about 5 wireless networks. Administration wants to know how can we shut down the student networks @ 11:30pm and then have them come on @ 6:00am. Othern than doing it manually is there another way?
3 REPLIES 3
Highlighted
Hall of Fame Master
Re: How can we put our wireless networks on a schedule
If you had WCS or NCS you could do that by setting up a schedule. There is no option on the WLC itself.
-Scott
Highlighted
Beginner
You may be able to use time based acl's.
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/timerang.html
Just a possible option you could explore.
Highlighted
create a time based ACL and apply it on the switch that is connecting to the AP. Keep the following in mind, LWAPP is UDP, the Data is 12222 and LWAPP Control is 12223.
With ACL block the data path but keep the control path up so AP(s) keep joined to the wlc.
time-range STUDENT
                  periodic weekends 00:00 to 23:59
                  periodic weekdays 00:00 to 05:59
                  periodic weekdays 23:30 to 23:59
access-list 101 deny udp any any eq 12222 time-range STUDENT
access-list 101 permit ip any any
Content for Community-Ad
Cisco COVID-19 Survey
