Community Helping Community
7555
Beginner
How do I configure a cisco 1131 AP to use WPA2 enterprise and authenticate to Active Directory
I have a Win2008 server set up as a radius server (192.168.32.71) and a stand alone AP (192.168.201.9) The AP is config is below:
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$IdUV$UvE2IJTNzHX6mW6Mmh3At0
ip subnet-zero
ip domain name TKGCORP.local
ip name-server 192.168.32.71
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
server 192.168.201.9 auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid ka_test
   vlan 201
   authentication open eap eap_methods1
   authentication network-eap eap_methods1
   guest-mode
power inline negotiation prestandard source
username Cisco password 7 112A1016141D
username tkgadmin privilege 15 password 7 022D167B06551D60
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 201 mode ciphers aes-ccm tkip
encryption key 1 size 128bit 7 673B0AA56FCB4E630D8E4856427E transmit-key
encryption mode wep mandatory
broadcast-key change 150
ssid ka_test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.201
encapsulation dot1Q 201
no ip route-cache
bridge-group 201
bridge-group 201 subscriber-loop-control
bridge-group 201 block-unknown-source
no bridge-group 201 source-learning
no bridge-group 201 unicast-flooding
bridge-group 201 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption key 1 size 128bit 7 B711059074E30B1E1D4E3EC038BB transmit-key
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface FastEthernet0.201
no ip route-cache
bridge-group 201
interface BVI1
ip address 192.168.201.9 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
  no authentication eapfast
  no authentication mac
  nas 192.168.201.9 key 7 010703174F
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.32.71 auth-port 1645 acct-port 1646 key 7 0835495D1D
radius-server host 192.168.201.9 auth-port 1812 acct-port 1813 key 7 0010161510
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
3 REPLIES 3
take a look at the following configuration guide.  Don't worry that it says ACS, just follow the RADIUS pieces.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Beginner
Sorry for the late reply Steve. The link you provided was extremely helpful here is what my config  looks like now:
ersion 12.3
no service pad
hostname ap
enable secret 5 $1$7vHS$YWCMbrlAgDUayKlOHhMlF1
ip subnet-zero
aaa new-model
server 192.168.32.71 auth-port 1645 acct-port 1646
dot11 ssid wap_test
   authentication key-management wpa
   guest-mode
   infrastructure-ssid optional
username Cisco password 7 047802150C2E
bridge irb
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid wap_test
station-role root
bridge-group 1
no ip address
no ip route-cache
shutdown
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
no ip route-cache
ip http server
radius-server host 192.168.32.71 auth-port 1645 acct-port 1646 key 7 071B245F5A
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
I get a login screen but it will not let me connect, on my radius server I have it set to allow a group that my username is in. Here are some debugs from when I try to connect to the AP:
ap#debug aaa  authentication
AAA Authentication debugging is on
ap#
*Mar  2 01:11:53.284: AAA/BIND(00000006): Bind i/f
*Mar  2 01:11:53.355: AAA/AUTHEN/PPP (00000006): Pick method list 'eap_methods'
*Mar  2 01:11:54.556: %DOT11-7-AUTH_FAILED: Station c0cb.3835.a102 Authentication failed
*Mar  2 01:11:55.280: AAA/BIND(00000007): Bind i/f
*Mar  2 01:11:55.404: AAA/AUTHEN/PPP (00000007): Pick method list 'eap_methods'
*Mar  2 01:11:56.349: AAA/BIND(00000008): Bind i/f
*Mar  2 01:11:56.525: AAA/AUTHEN/PPP (00000008): Pick method list 'eap_methods'
*Mar  2 01:11:57.300: AAA/BIND(00000009): Bind i/f
*Mar  2 01:11:58.070: AAA/BIND(0000000A): Bind i/f
*Mar  2 01:11:58.812: AAA/BIND(0000000B): Bind i/f
*Mar  2 01:12:15.470: AAA/AUTHEN/PPP (0000000B): Pick method list 'eap_methods'
*Mar  2 01:12:15.492: %DOT11-7-AUTH_FAILED: Station c0cb.3835.a102 Authentication failed
ap#undebug all
All possible debugging has been turned off
for the server NPS should be listening on 1812/1813 ( I believe it will still work with 1645/1646 if you allowed then in the setup).  What does the system log on the NPS server say?  There should be an NPS error as to why it rejected the user
HTH,
Steve
Content for Community-Ad
August's Community Spotlight Awards
